Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: acad 2004
  1. #11
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    That sounds like Object Snap Tracking.... make sure OTRACK is enabled on the the status bar
  2. #12
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    620
    Ive done that. Otrack only works after initializing line start point. I like seeing it after hitting line but before initializing start point. For instance, say I draw a straight horizontal line. Then I hit line command, go to end of line i already drew and scroll over endpoint. I use to then go straight above and the dotted line would follow my cursor. Then I could hit starting point of my next line knowing it was directly above endpoint of my first line. This possible in 2004/05
  3. #13
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Technically, I believe it's AutoTrack that you are having trouble with, after you pick the line's start point/basepoint, then it's Polar Tracking. (The two are not exclusive, they can be used simultaneously)
    Here's a demo with 2005, and I don't think there should be any significant differences.
  1. acad 2004 help
    By xolent in forum AutoCAD Beginners' Area
    Last Post: 18th Mar 2010, 11:02 pm
  2. 3D modeling in ACAD 2004
    By The Nickster in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st May 2006, 02:54 pm
  3. Acad 2004??
    By WannaBeCader in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jun 2005, 09:57 am
  4. dxf in acad 2004
    By cldryden in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2005, 09:10 pm
  5. ACAD 2004...
    By gina in forum AutoCAD Drawing Management & Output
    Last Post: 8th May 2003, 01:19 am
