Results 1 to 4 of 4
    Senior Member MillerMG's Avatar
    MillerMG's Computer Details
    Windows 7
    OPTIPLEX 3020
    Intel(R) Core(TM) i5-4570 CPU @ 3.30GHz
    8.0 GB
    The two in front of me. Dude, I got Dell's
    Civil
    MillerMG's Discipline Details
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    436
    Default Rotated Viewport now My Text is No Longer "E" with the viewport
    Used to use servCAD that had a tool that rotated text to "E" no matter how the viewport was rotated. Say the viewport is rotated where W is straight up. The text would need to have a rotation of "N" for it to be horizontal across the page in model space. Now that I have Civil 3D 2015 I do not see any tool pac or command that I can use to be efficient in this. The problem is time. Time is money. If a viewport was originally with North straight up and text had a rotation of "E" and I changed the viewport to West straight up, is there a quick way to change the properties of all the text? Besides match properties. It takes too long to individually select each text and rotate all of them. Even if I select all the text and change the rotation in the properties I have to go back and move all the text so it lines up with leaders and whatnot. I feel like I may have rambled on a little too much but hope this all makes sense. I am the worlds worst describer of my thoughts. Any insight would be wonderful.
    Thanks, Miller
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,579
    In the text style you can specify Match Text Orientation to layout, must be set to Annotative first. Maybe that will get you what you want.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Windows 7
    OPTIPLEX 3020
    8.0 GB
    Civil
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    436
    Thank you for the reply, not exactly what Im looking for
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,169
    There are a number of ways to select all the text quickly. Select similar and QSelect to name a couple. Changing the rotation is easy after that, as you stated. It would be quite a trick to have it all lined up for you and fix the leaders after the rotation.
    Drafting is a breeze.
  1. FIELDS: Viewport scale field showing "_XREF"
    By PEGAdevelopment in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Feb 2014, 04:10 pm
  2. How to using Lisp to "activate" a viewport
    By LauKwokFai in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jun 2012, 12:20 pm
  3. Extracting the "Custom scale" value from an existing viewport
    By landsurveying in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Dec 2011, 10:45 am
  4. "Freeze in current viewport" does not work...
    By bnsc in forum AutoCAD Beginners' Area
    Last Post: 17th Jun 2008, 07:28 pm
  5. Can text be rotated in 1 viewport only?
    By BOB'27T in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Feb 2008, 06:47 pm
Tags for this Thread
