Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Senior Member Sbeth85's Avatar
    Architecture 2014
    Sep 2013
    181
    Default Annotative dimensions in VP--> wrong scale?
    I have an annotative DimStyle that's been working fine- when I'm in a VP set 1:25 the dimensions will scale correctly. Out of nowhere, even through my VP is set to 1:25, all my dimensions are coming out with a 1:10 annotative scale, making them far too small.
    How come my dimensions aren't automatically in the same scale as my VP?
    DimAssoc is 2, Dimlfac is 1. In Model space with the scale set to 1:25 the dimensions come out in the appropriate size. Just in the VP in PS it's not coming out correctly.
    Thanks!
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Perhaps a duplicate scale, or a duplicate dimstyle?
    Can you attach a sample dwg that has the problem.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    What is the annotation scale of the viewport? It can be set to a different scale than the view scale of the viewport.
    Drafting is a breeze.
    Architecture 2014
    Sep 2013
    181
    RobDraw...
    1. Could you explain the difference between the annotation scale of a viewport and the viewscale of a viewport?
    2. I think I solved it, thanks to your hints... CANNOSCALE was set to 1:10 even though the VP was set to scale 1:25_1. So, I changed CANNOSCALE to 1:25_1 and now the dims are coming out ok. But how in the world did it ever get set to 1:10 to begin with? Before this whole thing the dims were coming out fine, their size was automatically matching the scale of the VP. What went wrong?
    Thank you both!
  5. #5
    Architecture 2014
    Sep 2013
    181
    nestly, here's a link, since it's too big for the cadtutor server:
    https://drive.google.com/file/d/0B9f...it?usp=sharing
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    The annotation scale sets which scale annotatively scaled objects will display at. It does not affect the display of other objects. Viewscale affects everything.
  7. #7
    Architecture 2014
    Sep 2013
    181
    Weird... how did mine get out of whack?
    Also, random question- how do you upload images like you just did? Do you do printscreen, save it in Paint and crop to size and save to a JPG, then upload it via Cadtutor? Is there a quicker method?
  8. #8
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    I can't answer the first question.
    That is almost exactly how I usually do it, except I save to .png. I also, use Windows' snipping tool.
  9. #9
    AutoCAD 2013
    Nov 2011
    6,048
    I use the Windows snipping tool, no additional software required.
  10. #10
    AutoCAD 2013
    Nov 2011
    6,048
    As you try to figure out how it got out of whack, check in your dimstyle manager,
    on the fit tab as shown in the screen snip. I believe that might cause such a problem,
    but could be wrong, as I don't use any of the Annotative features.
  1. Annotative dimensions change to annotative$0
    By jpugh in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th May 2013, 01:55 pm
  2. Annotative Scales - Am i doing it wrong?
    By guitarguy1685 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 13th Jul 2011, 08:46 am
  3. annotative dimensions losing the scale visually speaking
    By KiLLiNG-TiME in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Oct 2010, 05:52 pm
  4. Wrong unit or wrong scale?
    By annie26789 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Sep 2010, 07:07 pm
  5. displaying annotative dimensions in a viewport that not the correct scale?????????
    By MikeP in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jan 2010, 12:52 am
