Armin M Posted July 28, 2014 Share Posted July 28, 2014 Hello there, I have a specific problem creating a flatt Pattern from an Sheet Metal Part. My question is: Is it possible by the nature of the material and geometry to create such an flat pattern? Notice the Sweep Path has an circular sector. If it is possible, how can I do that , since I'm a newbie to the World of Sheet Metal . Thank you Armin M. Alu Sheet.ipt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 28, 2014 Share Posted July 28, 2014 Contour Flange and Contour Roll will be your friend. Quote Link to comment Share on other sites More sharing options...
Armin M Posted July 28, 2014 Author Share Posted July 28, 2014 Such an simple answer and it performed extremely well. Thank you. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 28, 2014 Share Posted July 28, 2014 Glad you figured it out - I intended to post example and then forgot. Quote Link to comment Share on other sites More sharing options...
Armin M Posted July 28, 2014 Author Share Posted July 28, 2014 No Biggie, found numerous examples of the command usages on youtube. Quote Link to comment Share on other sites More sharing options...
