Results 1 to 3 of 3
Thread: Broken OLE link
    Full Member lkenshalo's Avatar
    Revit MEP 2014
    Nov 2013
    51
    Default Broken OLE link
    I've got some panel schedules on an electrical schedule sheet that I need to edit from an outside source that are OLE objects - the problem is I don't have the original linked documents(excel spreadsheets I believe).
    Any way to convert these files to editable Autocad or Excel files so i can make some minor changes?
    Junior Member
    2001jonathon's Computer Details
    Windows 7 Pro
    AutoCAD 2015
    Dec 2007
    USA
    12
    The easiest way is to ask your outside person if they can send you the file. If not you will have to recreate the OLE in excel.
    Revit MEP 2014
    Nov 2013
    51
    That's what we ended up doing, but man it would be sweet if anyone could find a way to convert these files.
  1. dynamic block + named view + model space = broken link...
    By baker in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Apr 2013, 06:23 pm
  2. Can't re-establish broken link in 'XREF'
    By ADAM'S_APPLE in forum AutoCAD Beginners' Area
    Last Post: 11th Oct 2011, 01:53 pm
  3. OLE Link Broken
    By SMA in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 17th Aug 2010, 07:39 pm
  4. Is UCS broken in Acad 2010, or just broken in general?
    By MatthewDS in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Mar 2010, 11:23 pm
