Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2010
    Jul 2014
    3
    Default command dialog box
    In searching the help I keep seeing snippets of dialog boxes for certain, some commands that I am use to dealing with on the command line.
    Is there some place to turn on these dialog boxes?
    I do a cross between 2d and 3d so some dialog boxes would be most helpful.
    I've tried the filedia but it seems to deal mostly with open, save.
    Thank you for your help.
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    Win 7, Win 8
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2016
    Feb 2011
    TN or KY depends if I'm at work or home.
    924
    Try CMDDIA =1
    Murph
    Need a boat or camper for the weekend?
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Welcome to the Forum, Tahano50!
    For an exact response it will be useful to post the names of these commands.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,170
    Filedia 0 or 1 on or off, if you have off use ~ to force on as temporary a little gem of not known info. Note some commands are frustrating very hard to turn dialogs off.
  5. #5
    Full Member
    jarr3tt88's Computer Details
    8GB
    NVIDIA Quadro K600
    Architectural
    jarr3tt88's Discipline Details
    Draftsman
    Architectural
    New high end residential, townhouses, and commercial buildings
    AutoCAD LT 2014
    Nov 2013
    Long Island
    86
    You could put the - in front of the command and it should give you the command line version
    ie -purge, -hatch
    and if you still want the button version, you can edit the macro line of that button in the CUI. Just add the -
    And if you like hotkeys, I'm not sure if you can just edit this in the pgp file to add the - infront.
    Hope this helps
  1. command line input change to DCL dialog
    By nalsur8 in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Mar 2014, 01:32 am
  2. Command to open in dialog box via lisp
    By OMEGA-ThundeR in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Oct 2013, 04:30 pm
  3. Is it possible to do a zoom command while a dialog is loaded?
    By hemuni in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Jul 2011, 10:26 pm
  4. Changing Files Tab (Options Dialog Box) via command line?
    By jamesfear in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Apr 2011, 05:31 am
  5. FIND command without dialog box?
    By NoelStalker in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Nov 2009, 03:12 pm
