Results 1 to 2 of 2
    Senior Member bennyboy86's Avatar
    Structural
    bennyboy86's Discipline Details
    Structural Drafter
    Structural
    Revit 2018
    Jun 2011
    Sunshine Coast, Queensland, Australia
    117
    Question block text attribute
    Hi,
    i recently started a new job and standards are non existent here, been told can set up what i like.
    so i am trying to get the title block and a text attribute block set up.
    so here is my problem, i have created the text part, using ATTDEF, created all of them then used WBLOCK to create the insert...... when i go to insert nothing shows up on screen, no dialog block, nothing, if i click on blocks, i can see it in the list.....
    i can not remember how to do them haven't do it in 6 years...
    please help, i have attached a tester i have started....
    new block.dwg
    thankyou all
    Some people just need a high five.......to the face......with a chair!!!
    Structural
    Structural Drafter
    Structural
    Revit 2018
    Jun 2011
    117
    ok just worked it out, forgot to add text into the DEFAULT area..... problem sovled.....
  1. Change Text (Not Attribute Text) in Block
    By dinhvantrang in forum .NET, ObjectARX & VBA
    Last Post: 22nd Jan 2014, 06:48 am
  2. Convert block+text -----> block + attribute
    By bono05 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Sep 2013, 02:27 pm
  3. Block attribute text to annotative
    By mrharris78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Sep 2012, 06:31 am
  4. Backmasking attribute text in a block
    By Jon McElwain in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Dec 2011, 01:43 am
  5. Edit Attribute text in block
    By OMEGA-ThundeR in forum AutoCAD Drawing Management & Output
    Last Post: 30th Nov 2009, 04:14 pm
