Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Forum Newbie
    not specified
    Aug 2006
    3
    Default I cant trim a hatch
    Hi,
    I have a problem with this file. Whichever hatch I draw I cant trim it. I dont know its about. Please, can someone help me with this? I work in 2007.When I satrt a new drawing its all ok.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,208
    A hatch can be associative or not. The associative kind is "associated" with a border that you define by object(s), and you can trim it. The other kind is defined by a pick point, and you cannot trim it. Which kind of hatch are you making?
    Senior Member Ako's Avatar
    AutoCAD 2007
    Mar 2006
    Warrington UK
    309
    Not sure why you need to trim a hatch. If the hatch is associative you should be able to move the boundary that it is associated with and it will redraw itself to the new boundary. If you give us more information on what you need to achieve we may be able to help you more.
    Dave
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,117
    if it's relatively simple, just EXPLODE the hatch and make the needed trims.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  5. #5
    Forum Newbie
    not specified
    Aug 2006
    3
    It doesnt matter if I makeit associative or not, by selecting an object to hatch, or by picking point. I just got a drawing to work on, and I need sometimes to trim it, to make " holes" in it, that some objects be seen better, like some block etc. I know I can explode but its not the point. There must be something about that drawing what doesnt let to hatch behave on a common way. I tried to find some sistem variables which control it, but I didnt, so I am curious about it.
  6. #6
    AutoCAD 2007
    Mar 2006
    Warrington UK
    309
    If you want to put a hole in it you should be able to do this by drawing a circle, then double click the hatch, then use the add: select objects button from the dialogue box, then select your circle. This should save the trimming.
    Dave
  7. #7
    Forum Newbie
    not specified
    Aug 2006
    3
    Quote Originally Posted by Ako
    Dave
    Thanks,
    I didnt think on it. It saves the trimming. But there is something about the drawing, becouse it doesnt let trimming at all. Anyway, thanks I will do as you say.
  8. #8
    Junior Member
    AutoCAD 2008
    Dec 2008
    12
    Default Can't seem to get a hole to work
    Quote Originally Posted by Ako View Post
    Dave
    I tried doing the above instructions... somehow I still can't seem to get a "cut-out" or "hole" in the hatching area that I want. I first created a polyline to describe the bigger area I want hatched, and then I drew a smaller polyline rectangle inside of the bigger area. It keeps filling in my rectangle with hatching and doesn't remove it. When I try pressing different options in the hatching menu, it keeps telling me that my rectangle is not an island... Any help on this is greatly appreciated... Thanks.
  9. #9
    Junior Member
    AutoCAD 2008
    Dec 2008
    12
    AND when I try to tell it to "pick points" for hatching area it freezes up... so strange...
  10. #10
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Hit that little arrow at the bottom right corner of the hatch dialog box to expand to advanced options and turn on island detection, then make sure it is not set to IGNORE. That set of options is there so you can fill in across a large area with smaller objects inside it that may be "Under" the hatch by ignoring them, or leave them unhatched as 'islands' without having to select each one as a boundary object.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
