Results 1 to 5 of 5
    Full Member
    Architecture 2015
    Jul 2014
    65
    Default setting an object snap hierarchy
    Is there a way to set a 'snap hierarchy' for example, I want the 'perpendicular' snap to snap before the 'nearest' since it's more accurate. I would rather 'nearest' be the last resort snap if nothing else.
    thanks,
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    No hierarchy. Don't use nearest, problem solved.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Senior Member zaphod's Avatar
    AutoCAD 2017
    Sep 2013
    Houston, TX
    175
    I normally only use 4 object snaps; endpoint, center, midpoint, and intersection.
    For any other snap I need, I shift and right click during the command and pick the next needed snap.
    Full Member
    Architecture 2015
    Jul 2014
    65
    If i didn't need nearest sometimes I wouldn't use it rkent. thanks though.
    I think I am going to stick with the shift right click Zaphod - that solves it. Didn't know that was a thing.
  5. #5
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    I use the F keys for my osnap needs, hitting the one needed at the time. Like F2 for perp or F3 for nearest, this way you are certain that your pick is right where you want it. With running osnap you can pick in space and it will still make a pick, setting the osnap each time ensures that a pick in space will not result in a pick, instead you will see that it did not select anything and you have to go again.
  1. What is the difference between Object Snap Tracking and Object Snap?
    By prime333 in forum AutoCAD Beginners' Area
    Last Post: 25th Feb 2014, 02:14 am
  2. Object Snap Tracking Object Snap
    By Lee94 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 20th Feb 2014, 10:21 pm
  3. Object Snap doesn't snap at Intersection
    By dreamer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th May 2012, 04:55 pm
  4. Snap Mode and Object Snap Time Line
    By AQucsaiJr in forum AutoCAD General
    Last Post: 16th Jan 2010, 09:17 am
  5. Object snap setting disappeared~!
    By beegee_tw in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Jun 2009, 11:05 am
Tags for this Thread
