LISP - Merge color layers
nelsonavirama
Hi guys, need your help, I need a lisp to merge similar color layers into a new layer. I use 4 preset layers: grid, columns, walls, and various texts. Prepare the remaining drawing by the different layers with only 4 kinds of colors, but it is very wasteful to merge all those layers.
Thank you for your valuable help.
LAYMRG command?
I know the laymerge, but I need something faster. If you already have color layers, I might just be writing the "milispmerge" command and do the work of uniting all layers of similar colors. Is that many, many files every day. Thank you
in this page i found the nex code:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/LayMrg/td-p/3236852
(defun c:MergeTo0 (/ name layers)
(vl-load-com)
(vlax-for x (vla-get-layers
(cond (*AcadDoc*)
((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
(if (not (wcmatch (strcase (setq name (vla-get-name x))) "0,DEFPOINTS,*|*"))
(setq layers (cons name layers))
(cond ((not layers) (alert "Nothing to merge!"))
(T
(vl-cmdf "_.-layer" "_THAW" "0" "_SET" "0" "" "_.-laymrg")
(foreach layer layers (vl-cmdf "_NAME" layer))
(vl-cmdf "" "_NAME" "0" "_YES")
I want a similar command but grouping the layers to be joined by Color (use 4 colors white, 251, 6, 2, and 4 layers walls, columns, grid and text).
Thank you
