Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    Super Member bjenk8100's Avatar
    bjenk8100's Computer Details
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    Unhappy polar tracking and object tracking
    Hello,
    I posted a message not too long ago about having issues with polar tracking. It has been driving me insane. Well, I found out that autocad 2005 lite doesnt have object tracking, that's what I have been dependent on for years. Here is what I must overcome. Any help would be great. Imagine a detail section of a wall with headers, studs, drywall, windows, etc. I need to draw lines off of each of these entities with straight lines to the horizontal. I want to use the section and draw these lines to make an elevation drawing if this makes sense. I use to snap to say the top of the header drag over to the right a little and the object tracking would show I was still in line with the top of header so I would start my line knowing I was there to start an elevation. I would continue this process for all other entities in the section so that I would have exact elevations. The only thing I can think of is to draw lines away from the entities and then draw the elevation from those. I run into another problem. You cant object snap to that first line so that all each additional lines will perfectly line up with the first lines endpoint. Only thing next I can think of is draw all the lines and then a vertical line and trim from that so they are all in line. This is crazy to me. There must be an easier way. Please reveal something I might be missing or I do not know what I am going to do.
    Tnx!!!
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    2005?
    Since you don't have Object Tracking, you might get help with Ortho turned on. Then your cursor will be forced to either 180 deg or 90 deg depending on which way you move the cursor. You will still have to lay in a vertical trim line. You can start with an end point at the desired line on your section, move to either side to draw a line and your line will stay perfectly level with Ortho on. The lines don't have to be exactly the same length. Lay in a trim line that will catch them all when you are done with the horizontal lines.
    Even with Ortho on, you can still force in a diagonal line, say for a grade change, as long as you have end points to snap to, which will override Ortho.
    The same goes for vertical lines. I typically project upward from a floor plan for my vertical elevation lines and them trim the horizontal lines to them . With Ortho on, the lines will stay perfectly vertical.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    yes, that is my exact thinking. I just cant believe that object tracking is not in lite. That just sux. And yes 2005. I learned from 2009-14 but this company uses 2005 lite. Drawings are not super hard but you have to do crap like you mentioned. You cant even trim multiple lines. Thanks for your reply though. I think that probably is the only way. This company has five users. Upgrading to regular autocad would be impossible to convince this old owner.
    AutoCAD 2013
    Nov 2011
    6,049
    I have never used LT, do you have the Dynamic Input option available?
    Have you tried using the Extension O snap?
    Have you tried using full length crosshairs on your display?
    What are your auto tracking settings, if they exist on the Drafting tab,
    as shown in the snip.
    I too started on 2009, with the Dashboard!
  5. #5
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
  6. #6
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    ill double check tomorrow. almost positive there is no object tracking in lite. it has tracking after you start to draw but you cannot drag off something that tracks off of that to start at an exact level. I use a large crosshair but using that to line up to something away from where you are is not exact. Then applying dimensions would not be exact which is maybe one of the first things i learned, draw everything to scale or it will eat you alive later.
  7. #7
    windows 8 64 bit
    Construction
    AutoCAD 2018
    Sep 2009
    625
    i think ortho and then trim and start from the trim line is best option as of now. It isnt too big but later on something might be much larger and more detailed. Maybe Ill start looking for a better job, lol. Problem solved.
  8. #8
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,158
    Polar tracking should be there, try pressing the F10 key, or look at the settings. Another method I like, take a look at point filters in the help file, it takes a bit of figuring out (OK it took me a while, you might understand it straight away, I'm a bit slow) but it's a quick way of referencing just the x or y (or z) of existing geometry it saves all that trimming.
  9. #9
    AutoCAD 2013
    Nov 2011
    6,049
    Quote Originally Posted by steven-g View Post
    Sure steven, "you're a bit slow", as one of the forum's foremost LT alchemists, the only reason you might seem slow, is because you come up with so many outside the box approaches and solutions,
    to make the software do things that it CAN'T (supposedly).
  10. #10
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Object Snap Tracking is like Ortho on steriods. It pretty much eliminated using construction lines for me. So maybe that is something you haven't used much. Instead of using AutoCAD to detect an object snap, we did it manually. If you know you need something to be a certain distance from an endpoint, you would just draw a constuction line. There is nothing special about them, they are just a line possibly put on a non-plotting layer so that if you forget to erase it, it won't mess up your plot. Construction lines, a little creative geometry, and the previous tips will get you where you want to be.
    BTW, you can trim multiple objects. What exactly are you trying to accomplish? I'm sure there is a way.
    Drafting is a breeze.
  1. polar tracking problem
    By jrn in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Nov 2012, 04:15 pm
  2. Polar Tracking not snapping to polar angles
    By dayandow4 in forum AutoCAD General
    Last Post: 4th Nov 2010, 08:56 am
  3. Polar Tracking Backwards
    By skipsophrenic in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Nov 2008, 11:41 am
  4. polar tracking
    By good_m in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jun 2006, 01:46 pm
  5. Polar Tracking
    By EvilRufusKay in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Nov 2005, 05:29 pm
