Results 1 to 3 of 3
    Junior Member
    AutoCAD 2006
    Dec 2009
    PL
    16
    Default Number of sheet in TITLE BLOCK
    Dear All,
    I have small issue here which bother me a lot during my Acad activity.
    Is there a simple way to insert "Field" with number of following sheet in project?
    For now I am doing it "by-hand" and having 20-50sheets in file such option would save me a lot of time. Please find picture below.
    Thanks,
    Pete
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    Can be done simply by counting the number of layouts then just step through and change the 1 attribute in the title block on each layout. Others will advise how to do in sheet sets.
    Code:
    ;this is ;this is bits put together not tested
    (vl-load-com)
    (setq Doc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
    (setq LoCol (vla-get-Layouts Doc))
    (setq numlay (- (vla-get-Count LoCol) 1) ;need -1 to remove model
    setq oldtag1 "Total sheet") ; attribute tag name total sheet
    (setq ss1 (ssget "x"  '((0 . "INSERT") (2 . "Titleblockname"))))
    (setq inc (sslength ss1))
    (repeat inc
    (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS1 (setq inc (1- inc)) )) 'getattributes)
    (if (= oldtag1 (strcase (vla-get-tagstring att)))
    (vla-put-textstring att numlay)
    ) ; end if
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    If you will include the page number in layouts naming may adapt one of the Diesel expressions proposed here.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  1. Sheet Set Manager Title Block Problem
    By RyGuy in forum AutoCAD LT
    Last Post: 11th Jul 2014, 06:19 pm
  2. Replies: 0
    Last Post: 14th Jul 2013, 10:34 am
  3. How to populate block attribute (text) from title sheet data ?
    By milldew in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Apr 2011, 03:39 am
  4. How to extract and link title sheet block attributes to spreadsheets
    By kheajohn in forum AutoCAD Drawing Management & Output
    Last Post: 8th Sep 2010, 11:46 am
  5. How do i make a title block w/updated sheet numbers
    By Frank the Frowner in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Feb 2007, 08:11 pm
