Results 1 to 8 of 8
    Forum Newbie
    not applicable
    Aug 2014
    4
    Default Newbie. TTR will not snap properly
    Hi all.
    I'm learning CAD and using Draftsight V1R5.2
    The drawing is a tutorial drawing I found on a website.
    I have copied the drawing to a new .dwg and it still will not snap.
    The problem area is where the red pointer is.
    What the heck is going on here???
    Thanks a bunch.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,611
    Did you try using an "intersection" snap point? It should work.
    I opened your drawing in AutoCAD and I was able to snap to that point using "intersection". I can't test it in Draftsight at the moment because it is loaded on my laptop and not on my CAD computer which I am currently on.
    Forum Newbie
    not applicable
    Aug 2014
    4
    Thanks for the help.
    Here are the steps I just took.
    -Click draw circle
    -Type t
    -clicked snap to intersection
    -clicked lower left tangent
    -clicked right tangent
    -typed 1.75
    -enter
    Still got the same space on the right side.
    The right portion will not join at the tangent.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,611
    Use the Circle command with the Tan-Tan-Radius option. No snapping required.
    OK. Tried it in Draftsight and Circle with the Ttr option works like a charm after which you can snap to the intersection of the two circles.
  5. #5
    Forum Newbie
    not applicable
    Aug 2014
    4
    That is what I'm doing.
    It's not snapping on the right side tangent.
    When you did it in draftsight, is the right side touching that object?
    Can you trim the top of the circle?
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,611
    Yes, it is and yes, I can.
    And it is repeatable; I've done it three times in a row. No problem here.
    OK...I was able to reproduce your results on the fourth try. What did I do differently? I snapped to the endpoint of the arc that is at the end of the horizontal line that you should be snapping to. That, in essence, pulls the larger circle (r=1.75) away from and to the left of the smaller circle thus eliminating the intersection.
    Your approach was almost correct but not quite. Change it and your results should change as well.
  7. #7
    Forum Newbie
    not applicable
    Aug 2014
    4
    Ok.
    I see what I was doing wrong.
    When I was trying to trim, I was clicking an object that wasn't touching the 1.75 circle. DUH!
    As an aside,
    When zoomed all the way in on the right tangent, why isn't it touching?
    The bottom side tangent is touching.
    Also,
    Thanks for the help
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,611
    It all has to do with "pixels". I wouldn't worry about it. Next time you'll be more careful with your picks I imagine.
  1. What is the difference between Object Snap Tracking and Object Snap?
    By prime333 in forum AutoCAD Beginners' Area
    Last Post: 25th Feb 2014, 02:14 am
  2. Object Snap doesn't snap at Intersection
    By dreamer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th May 2012, 04:55 pm
  3. Turn Snap Mode Off Globaly (Snap not Osnap)
    By Larry711 in forum AutoCAD General
    Last Post: 9th Nov 2011, 11:59 pm
  4. Snap Mode and Object Snap Time Line
    By AQucsaiJr in forum AutoCAD General
    Last Post: 16th Jan 2010, 09:17 am
  5. cursor won't snap properly
    By alec in forum AutoCAD Beginners' Area
    Last Post: 1st May 2009, 05:19 pm
