Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    Full Member
    AutoCAD LT 2011
    Feb 2010
    Connecticut
    87
    Default How to edit these hatched areas
    Attached is a DWG with a flat template that will be cut and then bent to shape. The idea is to cut the negative spaces surrounded by the hatched areas. I understand what needs to be done and what I need for a final design however.....
    the negative space don't seem to have a pick point at the intersection of the hatched areas. As a novice, I don't know what technique might have created this design thus I don't understand how to get the negative spaces as shapes with vertices. I cannot get my cursor to pick on any interior intersection, as though the hatch areas don't actually exist.
    Can anyone explain how I should go about picking and outlining the desired areas? All the hatched areas could go away, I only am concerned with the perimeter and the many small negative spaces.
    Last edited by Quik&Easy; 2nd Aug 2014 at 01:28 pm. Reason: had other info I didn't mean to post publicly
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Would the Boundary command work?
    I tried and had some success but it wasn't 100%.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    This is what I managed to come up with on my first try.
    Full Member
    AutoCAD LT 2011
    Feb 2010
    Connecticut
    87
    I think part of the problem is my generic graphic card getting overwhelmed by the hatch's themselves. I'm picking each hatch and making it solid in hopes that it will lighten the load. With LT, I may not have the best solution for the problem regardless. I've never used the boundary command; I'll see if it will help. Thanks for taking a look so quickly.
    Edit: I've also tried surrounding the negative space with a circle and trimming to the edge of the circle but thats not working at all.
    I posted while you were. I see you're getting some spaces; do they match up if you overlay? In the upper left corner you have 2 that are touching but I don't think they are supposed to.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I just discovered another way. I'm using the 3DPolyline command.
  6. #6
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Boundary can work if you are only concerned with the void areas. Just type Boundary, then click internally in the void area. A polyline will be drawn around the void area. There may be one or two areas that might not have surrounding geometry that is completely touching, but for those you can probably draw a polyline boundary around them if you have apparent intersection as one of your snap points enabled.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Picked up a few extra (cyan color).
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    OK...this was just for fun.
  9. #9
    Full Member
    AutoCAD LT 2011
    Feb 2010
    Connecticut
    87
    Your cyan colors don't have boundaries according to the error message I get. Are all these voids on one plane? Is the any 3D in this drawing? I should probably pick and copy the perimeter and the islands off to one side and see what that looks like.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Corrected a few errors and added the final piece to the puzzle.
    I'm done.
  1. Sum of Hatched Areas
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Sep 2010, 01:38 pm
  2. Display text box on top of a hatched object
    By EngTech in forum AutoCAD Beginners' Area
    Last Post: 21st Sep 2009, 09:32 am
  3. Trimming hatched areas
    By matt4 in forum AutoCAD Beginners' Area
    Last Post: 22nd Apr 2009, 04:33 pm
  4. Drawing with a Closed / Hatched Polyline
    By Richard Martin in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jun 2005, 09:49 am
  5. Altering Hatched Text
    By hyposmurf in forum AutoCAD General
    Last Post: 22nd Mar 2003, 10:02 pm
