properties box does not show object data
designerstuart
hi all
i have a friend with v2014 and the properties box works, but does not show object data. so when a dimension (for example) is selected, the dimstyle, dim override, all that jazz does not show.
layer, colour etc do show as expected.
is this something to do with being in 2d wireframe view? i just want it to work like regular 2D autocad! - is this the wrong view? - i think nothing to do with this problem?
thank you!
Your dims show to be on the construction layer could that have something to do with it? I don't put dimensions on my plans so I never have to select them. Maybe try a different object and see what you get.
you see at the top of the image - the properties box does not even recognise that it is a dimension.... i have never seen this before?
Does this happen with all the drawings or just certain drawings. If you could post the drawing that would help as well.
i doubt is is a problem with the drawing (all drawings opened do this) but can post later if required.
when i select a line, and change its colour in properties box, all it actually changes is the current colour, not the object colour.
it's as if properties box does not recognise selection.
just to summarise further - it looks like the AutoACD 360 uninstaller has a bug that wipes out you properties box etc if you uninstall it. so i will have to reinstall AutoCAD to solve this - repair does not fix the problem. i wish i had found this link before - how to install without AutoCAD 360!
