JerryG Posted August 4, 2014 Share Posted August 4, 2014 Currently using Civil 3d 2014. I have to export to 2013 for a client since he is using 2014 LT. The problem I am seeing is when I export I get multiple lines of text on the Sections and Profiles. (please see attached) I can do the same thing using the same drawing on a separate computer but only get one line of text as expected. I have had him download and install the Object enabler for LT but it is Def on my end not his. So I am thinking I must have a setting that is controlling the text but I cannot for the life of me figure out what the heck it is. Any help would be much appreciated! As I am loosing sleep over this. Ok not really but it is frustrating! Quote Link to comment Share on other sites More sharing options...
JerryG Posted August 4, 2014 Author Share Posted August 4, 2014 I should have mentioned it looks fine in Paper Space since it puts all the text on separate layers. Quote Link to comment Share on other sites More sharing options...
JerryG Posted August 6, 2014 Author Share Posted August 6, 2014 I'm thinking this may have something to do with Annotative scales. Almost like when I export they all come out and play. Just cant seam to find any setting that make a difference. Quote Link to comment Share on other sites More sharing options...
JerryG Posted August 13, 2014 Author Share Posted August 13, 2014 Still having this issue. Any ideas out there on what to try? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 13, 2014 Share Posted August 13, 2014 Which settings have you looked at? How are you exporting the drawing? Did you check ANNOALLVISIBLE? ANNOALLVISIBLE Hides or displays annotative objects that do not support the current annotation scale. 0 Only annotative objects that support the current annotation scale are displayed 1 All annotative objects are displayed The ANNOALLVISIBLE setting is saved individually for model space and each layout. Note: When ANNOALLVISIBLE is set to 1, annotative objects that support more than one scale will only display one scale representation. Can you post the drawing that is doing this? Quote Link to comment Share on other sites More sharing options...
JerryG Posted August 14, 2014 Author Share Posted August 14, 2014 Ahhh I bet that's it! I'll check that tonight. Thank you! Quote Link to comment Share on other sites More sharing options...
JerryG Posted August 16, 2014 Author Share Posted August 16, 2014 Well that was it!!!! Thanks you so much SLW210 !! Huge help! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 18, 2014 Share Posted August 18, 2014 You are welcome!! Quote Link to comment Share on other sites More sharing options...
