Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Forum Newbie
    AutoCAD 2014
    Aug 2014
    7
    Default AutoLISP - Adding linetype & lineweight
    Hi Guys,
    I'm creating a layer setting pull down menu, in order to migrate my cad to revit I would like to define the linewight. So far I managed to create a command with a dashed line:
    (defun c:layA-SEC-LIH-005()
    (command "layer" "m" "A-SEC-LIH-005""C" "magenta" "" "l""DASHED2" "" "")
    and another one with the lineweight
    (command "layer" "m" "A-SEC-LIH-005""C" "magenta" "" "_LW" 0.10"" "")
    but I haven't been able to create one that combines the 2 of them.. any help?
    Cheers
    Roberto
    Senior Member
    feargt's Computer Details
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    not sure why u couldn't get it to work, but after entering the linetype, instead of exiting the command continue by giving the lineweight.
    (defun c:layA-SEC-LIH-005 ()
    (command "_-layer" "_m" "A-SEC-LIH-005" "_C" "magenta" "" "_l" "DASHED2" "_LW" "0.10" "" "" "")
    Forum Newbie
    AutoCAD 2014
    Aug 2014
    7
    Hi feargt,
    Still doesn't work, I get a prompt asking to "Enter and option" [? Make Set New Rename ON OFF Color LType LWeight Transparency MAterial Plot Freeze Thaw LOck Unlock state Description rEconcile]:
    Doesn't work for you if you use the pull down menu?
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    copy this direct on to the command line
    and see does it work. it works for me.
    if it does not work, press f2 and copy the text out so I can see where it stops working for you
  5. #5
    Forum Newbie
    AutoCAD 2014
    Aug 2014
    7
    as requested.. btw.. thanks for helping
    Command: (command "_-layer" "_m" "A-SEC-LIH-005" "_C" "magenta" "" "_l" "DASHED2" "_LW" "0.10" "" "" "")
    _-layer
    Current layer: "0"
    Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _m
    Enter name for new layer (becomes the current layer) <0>: A-SEC-LIH-005 Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _C
    New color [Truecolor/COlorbook] : magenta
    Enter name list of layer(s) for color 6 (magenta) <A-SEC-LIH-005>: Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _l
    Enter loaded linetype name or [?] <Continuous>: DASHED2
    Enter name list of layer(s) for linetype "DASHED2" <A-SEC-LIH-005>: _LW
    No matching layer names found.
    Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: 0.10
    Invalid option keyword.
  6. #6
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Please pay attention that you missed to indicate the layer that will set the linetype for:
    Code:
    ..."_L" "DASHED2" "A-SEC-LIH-005"...
    or
    Code:
    ..."_L" "DASHED2" ""...
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  7. #7
    Forum Newbie
    AutoCAD 2014
    Aug 2014
    7
    I will try tomorrow on another computer.. still doesn't work for me.. g nite
    Command: (command "_-layer" "_m" "A-SEC-HIDDEN" "_C" "magenta" "" "_LT" "DASHED2" "_LW" "0.10" "" "" "")
    _-layer
    Current layer: "0"
    Enter name for new layer (becomes the current layer) <0>: A-SEC-HIDDEN Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _C
    Enter name list of layer(s) for color 6 (magenta) <A-SEC-HIDDEN>: Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: _LT
    Enter name list of layer(s) for linetype "DASHED2" <A-SEC-HIDDEN>: _LW
    ; error: Function cancelled
    Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: *Cancel*
  8. #8
    Senior Member
    win 7
    Civil 3D 2012
    Sep 2008
    Austria
    428
    Thanks MSasu for picking that up:
    (command "_-layer" "_m" "A-SEC-LIH-005" "_C" "magenta" "" "_l" "DASHED2" "" "_LW" "0.10" "" "" "")
  9. #9
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,037
    You may want to create a global lisp defun that just passes the variables using either entmake, command or VL eg (newlay "A- SEC-LIH-005" 5 "dashed2" 0.1) then you can use in any lisp you make.
    Code:
    (defun newlay (lay col lt thick / )
    (command "_-layer" "_m" lay "_C" col "" "_l" lt "" "_LW" thick "" "" "")
  10. #10
    Senior Member
    Snownut's Computer Details
    Windows 10 Home premium
    Lenovo
    not applicable
    Nov 2010
    New Hampshire
    238
    Quote Originally Posted by BIGAL View Post
    Code:
    BIGAL, there seems to be some issues showing up in ACAD 2015 in using the "command" function in LISP. It seems AutoCad is slowly moving away from allowing this. The better way is to use the "vl-cmdf" function, this will require the (vl-load-com) at the beginning of the LISP.
  1. Change Bylayer ( color,lineweight,linetype )
    By vnanhvu in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Aug 2011, 05:14 pm
  2. Change a viewport linetype or lineweight? F1 key...
    By sean.svs in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Feb 2010, 12:16 am
  3. Colour/Lineweight/Linetype control on Ribbon
    By busseynova in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Feb 2010, 12:27 pm
  4. FOUND IT! - Linetype/Lineweight/Color Macro
    By amattintime in forum AutoCAD General
    Last Post: 30th Jun 2006, 08:07 pm
  5. User Defined Button?: Color/Lineweight/Linetype
    Last Post: 30th Jun 2006, 07:25 pm
Tags for this Thread
