cfculligan Posted August 6, 2014 Share Posted August 6, 2014 I have received a file from our GIS department with contours lines. Unfortunately, the contour lines do not have any elevations attached to them. This information is stored in the object data field "CONTOURELE". Would it be possible to create a routine that moves the value from the object data field to the elevation field. Hoping to quickly create surfaces and avoid any user error when transferring the contour elevation? Thank you for any help or advice as I am new to any sort of LISP routine. Quote Link to comment Share on other sites More sharing options...
Hippe013 Posted August 11, 2014 Share Posted August 11, 2014 Assuming you are using Civil 3d 2013. This functionality is already built in. No lisp is needed. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 11, 2014 Share Posted August 11, 2014 Is the file a shp you need to extract the levels of the contours it done through the MAP interface Murph_map can help here I am sure. Quote Link to comment Share on other sites More sharing options...
