Results 1 to 3 of 3
    Full Member
    ConMan's Computer Details
    Windows 7 Pro
    Lenovo Thinkstation S30
    Intel Xeon E5-1620 3.70 GHz
    32 GB
    NVIDIA Quadro K2000 2 GB
    Inventor 2016
    Jun 2012
    Oregon
    44
    Default AM Shaft calculator result box text error
    In AutoCAD Mechanical 2015 when I run the shaft calculation command the result table is filled with "variable" names as opposed to correct names. See screenshot below.
    That's what came out this morning. I opened an older drawing that had a shaft calculation that was done in 2014. I suppose since it was created correctly in 2014 it still displays correctly in 2015. See screenshot below.
    The only thing I could find about this after some googling was this thread at the Autodesk forums. I confirmed that the target location under Options was different between 2014 and 2015. However I can see no way to change target location in 2015 (and don't recall ever having to monkey with this in past). The "translator" folder didn't exist but I was able to create it and place a copy of the referenced "gefeko.mld" file in it but it didn't help. Tried running a new shaft calculation and still got same text field error.
    Anyone have any ideas how to fix this?
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,883
    I moved your thread to the Mechanical & MDT Forum.
    Full Member
    Windows 7 Pro
    32 GB
    Inventor 2016
    Jun 2012
    Oregon
    44
    It looks like Service Pack 2 may have resolved this, I don't get this error any more and don't recall changing any other settings.
  1. area command result write text
    By ekolman2003 in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Feb 2014, 06:01 pm
  2. TEXT JUSTIFY ON THE COMMAND LINE vs. TEXT JUSTIFY ON THE PROPERTIES, DIFFERENT RESULT
    By notview in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Dec 2013, 12:39 pm
  3. precision of the result
    By kalai in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Sep 2011, 11:56 am
  4. Error in my code, Changing text in a layer to a other text style.
    By yonderbob in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Sep 2011, 10:00 am
  5. Subtracting result
    By boyo in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Nov 2008, 06:32 pm
