Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Full Member
    Architecture 2015
    Jul 2014
    64
    hmm. I have a 14gb 64-bit OS and an AMD Athlon(tm) II X2 B26 Processor 3.20GHz whatever any of that means.... and windows 7. Maybe you could help.
  2. #12
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GT430 (H)
    256 gb SSD 0/ 1TB 1 (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2017
    Sep 2002
    Winston-Salem, NC - USA
    5,609
    Well to be honest kizaerf you don't have a high end workstation or you don't by today's standards. An Athlon II X2 is an older low end cpu with only 2 cores. Unfortunately this is where more cores make a difference in AutoCAD (2d redraws). Using PDFs in Autocad on my old Xeon based system slows it down to a snail's pace. I have the 4 core version of the Athlon II in my home box. It's not a bad unit just not high end.
    I would just use the clip command to isolate the areas that you need.
    Sean
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
  3. #13
    Full Member
    Architecture 2015
    Jul 2014
    64
    haha sweet - well it's my work computer and I just assumed it was 'high end' cause the one before was just awful! again, not even familiar! lol Good to know though. thanks!
  4. #14
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2017
    Sep 2002
    5,609
    Yeah not much help but I'd still rather use a PDF as opposed to a raster (png, jpg, etc) file. Just put the PDF on a layer that you can freeze and thaw as needed. This way when frozen it won't be redrawn by the system. Good luck
    Sean
  5. #15
    Forum Newbie
    Architecture 2014
    Jun 2014
    3
    Default How to speed up dwgs needing PDF attachment or underlay
    This is the best method that I could come up with....
    DO NOT pdfattach the PDF file into the actual dwg you are working in.
    Set up a new dwg which contains only the pdf attached in the correct location. THEN xref that dwg (with the PDF) into your dwg that requires the PDF underlay and you can trace the linework - There is no lag and it runs very smoothly.
  1. Autocad slows down over a period
    By Detailkim in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 10th Dec 2013, 07:11 am
  2. AutoCAD Slows down
    By Ells in forum AutoCAD General
    Last Post: 13th Jan 2012, 08:00 pm
  3. Hidden Shademode slows PC
    By Rock'n'roll Draughtsman in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Jun 2009, 11:37 am
  4. Cursor grabs data and slows down
    By grouch19 in forum AutoCAD General
    Last Post: 27th Nov 2008, 04:00 am
  5. Help - Autocad 2007 slows down
    By homasa in forum AutoCAD Drawing Management & Output
    Last Post: 8th Feb 2007, 09:37 pm
Tags for this Thread
