solid problem~pls help
Oh_Yes
i've just draw a model of a head with another softwave that can be save as autocad or 3ds max file..i have to use autocad/3ds max in order to convert the file into .stl file and able to be 3d print.When i import my file into autocad.the model is made by 3d face or ploylines...i can't use th convtosolid command to change it to be solid.then i try to use 3ds max to convert it,it was import as 3ds file and the model is made by editablemesh in 3ds max.i search some way trying to change it like shell in the modifiers.but it comes out a very ugly and uneven face...some of the faces go inside and some come outside.
i upload my file here so if anyone can help me how to convert the model to be solid~A Big ThxACE.rar
