Results 1 to 4 of 4
    Forum Newbie
    not specified
    Aug 2006
    4
    Default Dynamic ACAD Blocks
    I want to create a dynamic block that has elements that move and rotate... I can do both separately, but when I create a block now, I can move something fine if the block is not rotated dynamically. After I rotate, things do not move correctly, ie... they move relative to their original position, not rotated one.
    Thanks.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    dynamic blocks can get tricky.... there's so many "if's" involved... try posting up the file, maybe i could have a look at it.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Forum Newbie
    not specified
    Aug 2006
    4
    Thanks... the file is at: http://www.imgulin.com/Tag-Detail-Section.dwg
    If you do a dynamic rotate (using the little blue circle), and they try moving the lines, the lines seems to drift randomly.
    Any input is greatly appreciated.
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    well after messing with it a bit, i know what it's doing, i just don't know how to correct it. i've yet to come across a dynamic block that does this.
    it's keeping one part of the line at an absolute coordinate, that's the problem, and i'm too lazy to mess with it anymore, haha. unless someone knows exactly how to fix it, i'll try and deal with it more tomorrow. i tried a few different quick things that i thought might help but doesn't. so, i guess i'm stuck on it for now too, and i'd like to see how you overcome this little obstacle as well.
    - Tannar
