helpme Posted August 13, 2014 Share Posted August 13, 2014 Hi all i have some projects designed in digital projects and saved as ifc file when i export to revit all the files become as mass and i couldnt edit them. Please help Quote Link to comment Share on other sites More sharing options...
tzframpton Posted August 13, 2014 Share Posted August 13, 2014 IFC doesn't translate 100%. Revit 2015 made an astronomical stride in IFC support and is the best I've seen yet when exchanging IFC through import/export. Unless I can obtain the IFC files to test myself, it's hard to help or offer any further advice. IFC is tricky and a case by case basis, but one thing's for certain: it's never as seamless as you wished it was. They will stay generic models/mass elements. You will have to re-model from scratch if you want to do it right, unfortunately. Quote Link to comment Share on other sites More sharing options...
helpme Posted August 13, 2014 Author Share Posted August 13, 2014 i have some ifc file, when i import them in revit 2014 i can see them only on 3d view and it is in mass when i click on edit mass option and when i select it looks like a grouped file and when i try to explode it it gives an error saying 3d objects are not seen so only 2d something like that.... feel sad that i cant edit them or cant see the properties of the file: cry: Thank you so much for the answer..... Quote Link to comment Share on other sites More sharing options...
Rahim Shaikh Posted December 3, 2014 Share Posted December 3, 2014 send me your IFC file so i can test .... Quote Link to comment Share on other sites More sharing options...
