121madhu Posted August 13, 2014 Share Posted August 13, 2014 hi all i need Assemblies according to cross section please anyone help me iam getting problem in curb and median and cut fill slope please suggest me best tutorial pdf or video also thank you Quote Link to comment Share on other sites More sharing options...
121madhu Posted August 13, 2014 Author Share Posted August 13, 2014 check this sections for assemblies.dwg Quote Link to comment Share on other sites More sharing options...
JerryG Posted August 13, 2014 Share Posted August 13, 2014 Personally I would create it starting from the CL using a Sidewalk Assembly. Place it at -2% then curb etc etc. Once done select all the assemblys, right click and select mirror. Quote Link to comment Share on other sites More sharing options...
121madhu Posted August 14, 2014 Author Share Posted August 14, 2014 thank you jerryG, i know basic assemblies and done corridor also earth work quantity reports also done i need creating own sub assemblies according to cross section how to start Quote Link to comment Share on other sites More sharing options...
JerryG Posted August 14, 2014 Share Posted August 14, 2014 There is nothing there that is custom. All the assemblys you need are there. Start with the left side using a sidewalk assembly - give it the width/depth you need. then attach the curb assembly to the end of the sidewalk by selecting the little circle on the top left edge. Then insert the road assembly etc etc. make sure you are specifying that it is a "Left" attachment . For the landscape buffer use a sidewalk and give it a depth of .01 Quote Link to comment Share on other sites More sharing options...
121madhu Posted August 16, 2014 Author Share Posted August 16, 2014 how to create sub assemblies...? i tried polyline to assemblies that option is select poly line ok color also change now... * how to add code (right click add code but what i write there) * kerbstone (i need same like .dwg) * cut fill daylight option (need 1:4 only extend to ngl) when i create polyline to sub assemblies then add basic daylight or any other sub assemblies not accepted problem is the object is not sub assemblies. please suggest me, thank you. Quote Link to comment Share on other sites More sharing options...
