woodrowbarker Posted August 13, 2014 Share Posted August 13, 2014 Hi I'm using autocad architecture 2012. My problem is when I select a start point to draw my wall on a standard line drawing it doesn't show up. This hasn't been a problem before. I always create a line drawing to outline my floor plan then create the wall style and then add it in. I have loaded up other files and its working fine I also copied and paste my drawing into another file and it still isn't working. You can draw the wall anywhere else, you can also draw a line and select a start point from that and it works but not if I select a start point on a line in the drawing I have done. I don't see how those lines are any different. Any suggestions? Quote Link to comment Share on other sites More sharing options...
KTS Posted August 17, 2014 Share Posted August 17, 2014 Try using the wall designs in tool paletes to convert the lines into walls Quote Link to comment Share on other sites More sharing options...
