ALUX Posted August 13, 2014 Share Posted August 13, 2014 I am having trouble reading this drawing. First, how would I draw a 4-10x20 Oblong hole? (First picture) Second, why are there two dimensions for L1, L2, L3, and L4? (Second picture) Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 13, 2014 Share Posted August 13, 2014 First. A couple of circles and a couple of lines; trim as required would be one option. Second. Perhaps because the part was going to be made in two different sizes? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 13, 2014 Share Posted August 13, 2014 First, how would I draw a 4-10x20 Oblong hole? There are 4 oblong slots 10mmx20mm - I would use the circle, line and trim commands. Second, why are there two dimensions for L1, L2, L3, and L4? Looks like a single drawing depicting two different configurations for the part (table). Quote Link to comment Share on other sites More sharing options...
ALUX Posted August 13, 2014 Author Share Posted August 13, 2014 There are 4 oblong slots 10mmx20mm - I would use the circle, line and trim commands. Is the 20mm from the center of the circle or quadrant? Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 13, 2014 Share Posted August 13, 2014 I believe that would be a center-to-center distance although I've seen it both ways. Quote Link to comment Share on other sites More sharing options...
nukecad Posted August 13, 2014 Share Posted August 13, 2014 Is the 20mm from the center of the circle or quadrant? When dimensioned like that it is usually overall dimensions. If you look at it, then if those end radii were full circles they would meet at the centre line. So 10 wide by 20 overall length. (I would draw the two paralell lines and use the fillet command to do the ends). Quote Link to comment Share on other sites More sharing options...
