Results 1 to 6 of 6
    Forum Newbie
    jamesssydney's Computer Details
    Windows 7 64 Bit
    Asus
    AutoCAD 2013
    Aug 2014
    London
    1
    Default Slice a 3D polyline between a solid shape
    Evening All
    I work as a design assistant for a West End Set Designer who loves working in forced perspective & vanishing points.
    My question is how do I slice/trim a 3d polyline that runs through a solid. I basically want to cut the line once it touches the face of the solid. I would be also happy to add a node.
    Attached is a small example of the working file.
    Look forward to your responses
    Cheers
    James
    Super Member Patrick Hughes's Avatar
    Patrick Hughes's Computer Details
    Win 7 x64
    Dell Precision T7610
    Intel Xeon E5-2630 v2 (six core)
    32 Gb
    3 Gb Nvidia Quadro K4000
    1 TB
    2x 1920x1080 Dell Ultrasharp U2312HM
    Mechanical
    Patrick Hughes's Discipline Details
    Self unemployed - Machine Design
    Mechanical
    Machine Design
    AutoCAD 2015
    May 2008
    Rockford, Illinois
    763
    James,
    I don't believe that can be done. However as an alternative perhaps you can extrude/sweep a small circle along the 3D polyline then create an interference solid, subtract from the swept solid then trim by the face.
    www.cadtempo.com
    Time tracking for AutoCAD, Inventor, Revit and other CAD programs
    Senior Member rvpas's Avatar
    rvpas's Computer Details
    Seven Pro
    laptop HP EliteBook 8760w - workstation hp
    Architectural
    rvpas's Discipline Details
    building CAD designer and AUTOCAD ATC instructor free lance
    Architectural
    Help to design building with architect work with REVIT and AUTOCAD during the step of conception, follow the contruction site, building survey. ATC Instructor with trainng center 2d 3d AUTOCAD and REVIT
    AutoCAD 2015
    Apr 2010
    Rochester NY
    180
    Hi James,
    To find a point of intersection between the line and the face.
    you can use the old command 'cal and expression ilp
    Command: _break
    Select object:
    Specify second break point or [First point]: _f
    Specify first break point: 'cal
    >>>> Expression: ilp(end,end,end,end,end)
    >>>> Select entity for END snap:
    Resuming BREAK command.
    Specify first break point: 266.3632932838,44.570154537148,92.980182909103
    Specify second break point: @
    'cal open the Prompt Calculator inside the comand see help for more informations.
    ilp(end,end,end,end,end) is an expression, end is object snap
    ilp(pt1,pt2,pt3,pt4,pt5) for our example :
    - pt1 and pt2 it's extremity of the line
    - pt3, pt4 and pt5 it's 3 points of the face
    Good luck
    Senior Member
    sevdo2000's Computer Details
    Windows XP x86
    Asrock NF5 Alive
    Athlon 6000+ X2
    4GB 800 MHZ
    GF 8800 GT
    250GB Seagate
    LG 22"
    AutoCAD 2010
    Mar 2008
    113
    Try "imprint" command. Select 3D solid, select 3D poly and - enter. It makes point on face of 3D solid, and you can break (stretch) poly to these two points (in this case it intersects two faces), can snap points, lines and etc. Luck!
  5. #5
    Win 7 x64
    32 Gb
    1 TB
    Mechanical
    Mechanical
    Machine Design
    AutoCAD 2015
    May 2008
    Rockford, Illinois
    763
    Hmm, I hadn't checked the drawing until now. It's as simple as drawing lines in the top view and trimming the 3D poly.
    Edit: That is for the example which is a very simple rectangular box type solid. A more complex solis will require some UCS manipulation and such. Or perhaps even my original suggestion.
    www.cadtempo.com
  6. #6
    Full Member
    AutoCAD 2009
    Jan 2009
    65
    AutoCAD 2014 - Project to view ( project the curve to the surface of the solid). Then trim the curve with the projected curve.
    EXAMPLE.dwg
  1. Slice/trim? Solid or surface?
    By byk3bep in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Jun 2013, 11:19 am
  2. Slice using network solid
    By Al_H_C in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Oct 2012, 03:26 pm
  3. Slice in solid
    By il0veaut0cad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd May 2011, 11:02 pm
  4. Slice 3d Solid Along An Arc Surface
    By CiCAD in forum AutoCAD General
    Last Post: 12th Jan 2011, 10:53 pm
  5. how to slice solid with 3dplane
    By gujde in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Apr 2004, 05:55 pm
Tags for this Thread
