Results 1 to 5 of 5
    Forum Newbie
    Tataboutlamine's Computer Details
    Windows 7 x64
    Dell
    Civil
    Tataboutlamine's Discipline Details
    Junior Engineer & Project Manager
    Civil
    Urban water management - distribution, retention and evacuation.
    AutoCAD LT 2014
    Aug 2014
    Montreal, Canada
    1
    Default Block-based multileader has weird color behavior
    Hi.
    I'm trying to create a block-based multileader style in ACAD 2014 LT, but I'm running in a weird color behavior issue. below is the block used as the base as seen in block editor :
    The issue arise with the hatch. I've been using a version without a hatch for a long time without any issues ever, but I would like to have hatch so that I don't have to trim overlapping lines or add boundaries to background hatches, which make any kind of afterthought modifications a pain.
    In model space, everything seems fine :
    But when seen in paper space, the hatch suddenly takes the layer color (in this case, blue). It's the same wether the multileader is copied directly on the paper or viewed through a viewport.
    Why is this happening and is there a workaround? I can't use a wipeout because for some reason, I can't do an ellipsoid wipeout and you can't make an ellipse with polyline arcs.
    Thank you
    Full Member
    dal-designs's Computer Details
    Windows 7
    HP Compaq Elite 8300 SFF
    Construction
    dal-designs's Discipline Details
    Designer in Oil and Gas Industry
    Construction
    facilities planning (retail/wholesale fuels and chemicals) aerial surveying and GIS mapping; building design, facilities planning, land development
    AutoCAD 2015
    Feb 2014
    Victoria, Texas
    54
    Try putting the hatch (SOLID?) to True Color 255,255,255. Make sure that it is drawordered below the text and ellipse.
    Not sure this will fix the problem, but it sounds suspiciously like similar problems I've had with blocks...
    Forum Newbie
    Electrical
    AutoCAD 2013
    Feb 2017
    3
    Default SOLVED: I believe I have a solution to this problem.
    the trick is, to define the block and insert it into the drawing BEFORE using the multileader that uses the block.
    In my case, I have a circle with a blanking mask at the back, and an attribute (to make a number in the middle of the circle). this makes up my block.
    if you insert the block BEFORE the multileader, it should work fine.
    Attached are 2 files for you to try. one is a block, the other has a multileader that uses that block. Remember, the problem only appears in Paper space so you should test it there.
    -Jeffmultileader.dwgsheet note_x96.dwg
    Forum Newbie
    Electrical
    AutoCAD 2013
    Feb 2017
    3
    Star On second thought....
    This represents a "Workaround", I really am not sure why my combination of block and Multileader works, but it does at least for me.
    I found that putting the blanking hatch on layer zero may cause the problem in the first place; you may see that I put my blanking hatch on a layer with color 251 (my blanking color) and then I further forced the object (the hatch) to have color = 251.
    Good luck
    -Jw
  5. #5
    Forum Newbie
    Electrical
    AutoCAD 2013
    Feb 2017
    3
    One small correction: I actually had the hatch's color set to BYLAYER in the Block. -Jw
    (NOTE: I have not found out how to edit my posts. Hence the 3 posts in a row.
    Not easy to find that information on this site. I emailed so maybe they will tell me soon.)
  1. Weird blurry cursor behavior! wtf?
    By Sbeth85 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Feb 2014, 10:50 am
  2. Weird behavior of the visual lisp de******
    By samifox in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jul 2013, 02:07 am
  3. Balloning based on a multileader
    By elfert in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Dec 2011, 10:33 pm
  4. Block behavior
    By Timothyl in forum AutoCAD Beginners' Area
    Last Post: 24th Jun 2011, 08:22 am
  5. generate layers based on color?
    By arqi in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Feb 2011, 06:51 am
Tags for this Thread
