wcmatch by file extension
jnky
Hi all,
Im trying to create a variable when an existing variable has a certain file extension associated with it.
This is the code
(if (wcmatch (strcase plotstyle) "*.stb")
(setq stbctb "White_200")
I have been successful with the following code but ultimately I need the above to work.
(if (wcmatch (strcase plotstyle) "MR*")
Thanks in advance
It seems to load but stbctb = nil when using the extension, If I use mr* stbctb = White_200....
The file associated with 'plotstyle' is "MR_filename.stb" the MR is common but if users create another plotstyle prefixed with MR then it will fail.
What BIGAL pointed is that you should pay attention to STRCASE function's behavior; using it without the second argument set to T, it will return the string as uppercase, not lower case as expected by your comparison.
(wcmatch (strcase "test.stb")     "*.stb")   ;nil
(wcmatch (strcase "test.stb")     "*.STB")   ;T
(wcmatch (strcase "test.stb" nil) "*.stb")   ;nil
(wcmatch (strcase "test.stb" nil) "*.STB")   ;T
(wcmatch (strcase "test.stb" T)   "*.stb")   ;T
(wcmatch (strcase "test.stb" T)   "*.STB")   ;nil
