Results 1 to 4 of 4
    Full Member
    Architecture 2015
    Jul 2014
    64
    Default Line display not straight - graphic display Issues
    Has anyone ever run into this? As in the image, the line is at 0 degrees and supposedly straight but sure doesn't look it. any reason this may be? Also, sometimes it displays as lines overlapping when there is only one line. This is just in this particular drawing. It's been funky and the cursors are also the wrong color and all these problems occurred at the same time
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    The UCS is probably rotated. Use UCS, World, and maybe Plan, World to get it all back to normal.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    The two colored crosshairs indicates that you are in a 3D view. Change your view to Plan.
    Drafting is a breeze.
    Full Member
    Architecture 2015
    Jul 2014
    64
    Quote Originally Posted by RobDraw View Post
    Thank you! this solved my problem. I don't know the options in the top left disappeared but I got it back.
  1. display & output issues
    By Ravenstown in forum AutoCAD Drawing Management & Output
    Last Post: 20th Aug 2012, 11:31 am
  2. Display Issues
    By MADDCATT in forum Hardware & Operating Systems
    Last Post: 21st Jan 2012, 06:27 pm
  3. MEP Display Issues
    By Kremer in forum AutoCAD Drawing Management & Output
    Last Post: 25th Oct 2011, 01:53 am
  4. Line weight display issues
    By meecpc in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Nov 2008, 05:43 pm
  5. 3D graphic display
    By minimad in forum AutoCAD Drawing Management & Output
    Last Post: 30th Jul 2005, 01:13 pm
Tags for this Thread
