How to blend a radius - Autocad 2000
Stanier
Hello - I am trying to draw up a globe valve for a model steam fitting and am having trouble in finding out how to blend two radii. Essentially the globe valve is a 7/16" diameter sphere with two inline connections at 180 degrees at 1/4" and 3/16" diameters respectively. My query is this. How do I blend (if that is the term) the central globe into the 180 degree connections to give that professional appearance and avoid the lolly pop-on-a-stick appearance. Kind regards :)
Perhaps use the Circle command and the tan-tan-radius option? Post an image of what you have or attach a copy of the drawing to your next post.
Here is an example of a 2D globe valve we've used on one of our steam mains.
And here is an example of a 2D globe valve we've used on our cooling water lines.
Both blocks were downloaded from another website and not created in house.
