Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    Junior Member
    sidhu412's Computer Details
    Windows 7
    Dell Optiplex 9020
    Landscape
    sidhu412's Discipline Details
    Snr. CAD Designer
    Landscape
    AutoCAD 2014
    Oct 2011
    Saudi Arabia
    21
    Default EXTRIM Between Two Lines
    Hello,
    Is there anyway or LISP to use EXTrim between two Lines as shown in the following Screenshot.
    Thank you,
    Regards,
    Sidhu
    Click image for larger version
Name:	MULTI EXTRIM.jpg
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    EXTRIM is not set up for picking two cutting edges so you'll have to find and use a custom lisp routine to accomplish the task.
    Senior Member
    OMEGA-ThundeR's Computer Details
    Windows 10
    HP Z440
    Civil
    OMEGA-ThundeR's Discipline Details
    Civil Engineer (CAD Design)
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    322
    You can fence trim. Do 'Trim' select outer and inner circle, confirm, when asked to select objects to trim enter 'Fence' and you can draw a line over the objects you want to trim (between outer and inner circle). Perhaps the only way...
    Junior Member
    Windows 7
    Dell Optiplex 9020
    Landscape
    Snr. CAD Designer
    Landscape
    AutoCAD 2014
    Oct 2011
    Saudi Arabia
    21
    Quote Originally Posted by OMEGA-ThundeR View Post
    You can fence trim. Do 'Trim' select outer and inner circle, confirm, when asked to select objects to trim enter 'fence' and you can draw a line on the objects you want to trim. Perhaps the only way...
    Thnx for reply. I know the Fence function but I have hundreds of Objects need to be trimmed and fence is time taking option. I believe if someone can provide me with Custom Lisp Program as ReMark said above, it could be done more quickly and easily.
    Regards,
    Sidhu
  5. #5
    Super Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2014
    Feb 2010
    Belgrade, Serbia, Europe
    1,297
    You need to draw polygon with more sides as much as better... Than you should make list of its vertices and pass that list to command trim with fence option... Of course in trim command you have to select inner and outer circles...
    HTH
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
  6. #6
    Senior Member
    Windows 10
    HP Z440
    Civil
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    322
    As far as an 'lisp' i can make to skip some typing to speed up manual progress;
    Code:
    ;;; FenceTRim
    (Defun C:ftr ()
    (command "_trim" pause pause "" "f")
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    I think I found what you are looking for. Curiously it was written by marko_ribar and it is called MExtrim.
  8. #8
    Junior Member
    Windows 7
    Dell Optiplex 9020
    Landscape
    Snr. CAD Designer
    Landscape
    AutoCAD 2014
    Oct 2011
    Saudi Arabia
    21
    Can you please send me a link of it???
  9. #9
    Senior Member
    Windows 10
    HP Z440
    Civil
    Civil
    AutoCAD 2017
    Oct 2008
    Netherlands
    322
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    I can't because I don't have a link to it. Anyway, it did work the first time I used it in a test drawing but on two subsequent attempts in the same drawing it failed to work (it did trim but the results were not what was seen first time round). I don't know why that is. I'm still in "test" mode.
    Second test failed. I guess it's back to searching for an answer.
    Sorry about that.
  1. Adding " Extrim" command to my Tool Platte
    By samifox in forum AutoCAD General
    Last Post: 31st Jan 2013, 04:49 pm
  2. Extrim not working in lisp
    By BIGAL in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jan 2013, 12:53 am
  3. 2D circle jagged lines, 3D model " hidden" jagged lines. How do i get smooth lines?
    By richarda2012 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Oct 2012, 09:21 am
  4. Extrim command
    By chizifreshi in forum AutoCAD General
    Last Post: 30th Jan 2012, 02:57 pm
  5. Replies: 16
    Last Post: 3rd Dec 2008, 03:45 pm
Tags for this Thread
