Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 23
  1. #11
    Super Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2014
    Feb 2010
    Belgrade, Serbia, Europe
    1,245
    Slightly different than I proposed with polygon - now obtaining points directly from middle distance of 2 radius...
    Code:
    (defun c:trim_between_2_concentic_circles ( / inner_circle outer_circle c1 c2 c r1 r2 r k p pl )
      (setq inner_circle (car (entsel "\nPick inner circle")))
      (setq outer_circle (car (entsel "\nPick outer circle")))
      (setq c1 (cdr (assoc 10 (entget inner_circle))))
      (setq c2 (cdr (assoc 10 (entget outer_circle))))
      (setq c (mapcar '* (mapcar '+ c1 c2) '(0.5 0.5 0.5)))
      (setq r1 (cdr (assoc 40 (entget inner_circle))))
      (setq r2 (cdr (assoc 40 (entget outer_circle))))
      (setq r (/ (+ r1 r2) 2.0))
      (setq k -1.0)
      (repeat 360
        (setq p (polar c (cvunit (setq k (1+ k)) "degrees" "radians") r))
        (setq pl (cons p pl))
      (setq pl (cons (polar c 0.0 r) pl))
      (command "_.trim" inner_circle outer_circle "" "_F")
      (foreach p pl
        (command p)
      (while (> (getvar 'cmdactive) 0) (command ""))
    (defun c:tb2cc nil (c:trim_between_2_concentic_circles))
    HTH, M.R.
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,737
    Thank you marko. Works like a charm.
  3. #13
    Junior Member
    sidhu412's Computer Details
    Windows 7
    Dell Optiplex 9020
    Landscape
    sidhu412's Discipline Details
    Snr. CAD Designer
    Landscape
    AutoCAD 2014
    Oct 2011
    Saudi Arabia
    21
    I can't because I don't have a link to it. Anyway, it did work the first time I used it in a test drawing but on two subsequent attempts in the same drawing it failed to work (it did trim but the results were not what was seen first time round). I don't know why that is. I'm still in "test" mode.
    Second test failed. I guess it's back to searching for an answer.
    Sorry about that.
    It's ok no problem.
    I found the LISP Code on the link given by OMEGA-ThundeR and tried it. But it can only trim the lines intersecting the Closed Objects. FYI, I drew the Circle just to let people understand my query otherwise I have sets of Open Polylines including Arcs & Straight Lines (irregular) So The MEXTRIM or the Polygon method (Described by Mr. Marko-Ribar) will not work.
    will be grateful if there's something else you guys can do.
    Thank you,
    Regards,
    Sidhu
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,737
    sidhu: Did you not see the new lisp program marko included in his last post? It does what you asked for. Check it out.
  5. #15
    Junior Member
    Windows 7
    Dell Optiplex 9020
    Landscape
    Snr. CAD Designer
    Landscape
    AutoCAD 2014
    Oct 2011
    Saudi Arabia
    21
    Quote Originally Posted by marko_ribar View Post
    Code:
      (setq k -1.0)
      (repeat 360
      (foreach p pl
        (command p)
    HTH, M.R.
    Sir,
    It works fine but still I need to specify the Fence Path. This is 90% of what I need. If you can only edit it little bit and remove the Fence Function, So it will trim every Line in between the Circel / Polyline 1 & Circle / Polyline 2.
    Regards,
    Sidhu
  6. #16
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2014
    Feb 2010
    1,245
    sidhu412, If your concentric circles lie in some UCS different than WCS, I suggest that you use this revision (also added OSMODE checking - you can add this 2 first lines and in previous code and one last before (princ))
    Code:
    (defun c:trim_between_2_concentic_circles ( / osm inner_circle outer_circle c1 c1w c2 c2w cw c r1 r2 r k p pl )
      (setq osm (getvar 'osmode))
      (setvar 'osmode 0)
      (while (/= (cdr (assoc 0 (entget inner_circle))) "CIRCLE")
        (prompt "\nPicked entity isn't circle entity, try again...")
      (while (/= (cdr (assoc 0 (entget outer_circle))) "CIRCLE")
      (setq c1w (trans c1 inner_circle 0))
      (setq c2w (trans c2 outer_circle 0))
      (setq cw (mapcar '* (mapcar '+ c1w c2w) '(0.5 0.5 0.5)))
      (setq c (trans cw 0 1))
      (setq k -1.0)
      (repeat 360
      (foreach p pl
        (command p)
      (setvar 'osmode osm)
    BTW. This code by OMEGA-ThundeR is more general and I strongly suggest that you use it in many various situations, where EXTRIM can't provide desired results...
    Code:
    ;;; FenceTRim
    (Defun C:ftr ()
      (command "_trim" pause pause "" "f")
    Regards, M.R.
    M.R. on YouTube
  7. #17
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2014
    Feb 2010
    1,245
    Here is another approach... Try it and see if you get desired results...
    Load posted code :
    Code:
    (defun colect_entdata ( / ss i ent entdata )
      (setq ss (ssget "_X"))
      (setq i -1)
      (while (setq ent (ssname ss (setq i (1+ i))))
        (setq entdata (cons (entget ent) entdata))
      entdata
    (defun c:store_entdata nil
      (setq entdata (colect_entdata))
    ;;; Modify entities ;;;
    (defun colect_modified_entdata ( / ss i ent entdatachk entdatamod )
      (setq i -1)
        (setq entdatachk (cons (entget ent) entdatachk))
      (foreach data entdatachk
        (if (not (vl-some '(lambda ( x ) (equal x data 1e-6)) entdata))
          (setq entdatamod (cons data entdatamod))
      entdatamod
    (defun c:sel_mod_ents ( / ss )
      (setq ss (ssadd))
      (foreach data (colect_modified_entdata)
        (ssadd (cdr (assoc -1 data)) ss)
      (sssetfirst nil ss)
    (alert "\nFirstly type : store_entdata \nThen modify entities \nFinally type : sel_mod_ents \nAt the end type : (setq entdata nil)")
    1. Firstly type : store_entdata
    2. Use "EXTRIM" command - pick first curve and pick point inside area you want to be extrimmed...
    3. Type : sel_mod_ents
    4. Press ctrl+shift+c (copybase) and enter point : 0,0,0
    5. Type : (setq entdata nil)
    6. Type : U (undo) - drawing should be exactly like starting - before 2. process
    7. Use "EXTRIM" command - pick second curve and pick point inside area you want to be extrimmed...
    8. Press ctrl+v (paste) and enter point : 0,0,0
    That's it... Try it and tell me how it works...
    HTH, M.R.
    M.R. on YouTube
  8. #18
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2014
    Feb 2010
    1,245
    I thought, why wouldn't I automate this steps into single lisp, and I did it... So try this version...
    Code:
      (setq i -1)
      entdata
    (defun store_entdata nil
      (setq i -1)
      entdatamod
    (defun sel_mod_ents nil
      (setq ss (ssadd))
    ;;; Main command function ;;;
    (defun c:extrim_between_2_curves ( / hig osm c1 c2 p ss entdata )
      (vl-load-com)
      (setq hig (getvar 'highlight))
      (setvar 'osmode 0)
      (if (not (or etrim (not (vl-catch-all-error-p (vl-catch-all-apply 'load (list (findfile "extrim.lsp")))))))
          (alert "\nExpress Tool EXTRIM not available - quitting...")
          (exit)
      (setq c1 (car (entsel "\nPick first curve")))
      (while (not (numberp (vlax-curve-getstartparam c1)))
        (prompt "\nPicked entity isn't curve entity. Try again...")
      (setq c2 (car (entsel "\nPick second curve")))
      (while (not (numberp (vlax-curve-getstartparam c2)))
      (initget 1)
      (setq p (getpoint "\nPick or specify point between 2 prviously picked curves where do you want extrim to be processed : "))
      (store_entdata)
      (etrim c1 p)
      (sel_mod_ents)
      (command "_.copybase" '(0.0 0.0 0.0) ss "")
      (command "_.undo" "3")
      (etrim c2 p)
      (command "_.pasteclip" '(0.0 0.0 0.0))
      (setvar 'highlight hig)
    (defun c:exb2c nil (c:extrim_between_2_curves))
    HTH, M.R.
    Regards...
    M.R. on YouTube
  9. #19
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,162
    oops forgot to read page two
    A facet.lsp anyway for something like this problem a few extra lines and done trim between two circles. Like above new rad is just (rad1+rad2)/2, pick two circles then trim using Fence avoids using vlax-curve old fashioned lisp.
    Code:
    (setq num (getreal "\nEnter number of facets"))
    (setq rad (getreal "\nEnter radius"))
    (setq cenpt (getpoint "\nPick centre pt"))
    (setq ang 0.0)
    (setq angdiff (/ (* pi 2.0) num))
    (repeat (fix num)
    (setq pt1 (polar cenpt ang rad))
    (setq facets (cons pt1 facets))
    (setq ang (+ angdiff ang))
    (princ facets)
  10. #20
    Junior Member
    Windows 7
    Dell Optiplex 9020
    Landscape
    Snr. CAD Designer
    Landscape
    AutoCAD 2014
    Oct 2011
    Saudi Arabia
    21
    Code:
      (setq i -1)
      entdata
      (setq i -1)
      entdatamod
      (setq ss (ssadd))
      (vl-load-com)
      (setvar 'osmode 0)
          (exit)
      (initget 1)
      (store_entdata)
      (etrim c1 p)
      (sel_mod_ents)
      (etrim c2 p)
    HTH, M.R.
    Regards...
    Bingooooooooooo
    Great.........!
    That's 100% What I needed You are Genius Mr. Marko_Ribar.
    Thanxxxxxx a lot
    Regards,
    Sidhu
  1. Adding " Extrim" command to my Tool Platte
    By samifox in forum AutoCAD General
    Last Post: 31st Jan 2013, 04:49 pm
  2. Extrim not working in lisp
    By BIGAL in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jan 2013, 12:53 am
  3. 2D circle jagged lines, 3D model " hidden" jagged lines. How do i get smooth lines?
    By richarda2012 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Oct 2012, 09:21 am
  4. Extrim command
    By chizifreshi in forum AutoCAD General
    Last Post: 30th Jan 2012, 02:57 pm
  5. Replies: 16
    Last Post: 3rd Dec 2008, 03:45 pm
Tags for this Thread
