Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
  1. #21
    Super Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2014
    Feb 2010
    Belgrade, Serbia, Europe
    1,243
    Quote Originally Posted by sidhu412 View Post
    Bingooooooooooo
    Great.........!
    That's 100% What I needed You are Genius Mr. Marko_Ribar.
    Thanxxxxxx a lot
    Regards,
    Sidhu
    You're welcome, Sidhu...
    All the best in your work, I hope you'll find useful posted code...
    M.R.
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
  2. #22
    Senior Member troggarf's Avatar
    troggarf's Computer Details
    Windows 8.1
    AutoCAD 2016
    Oct 2010
    Littleton, Co
    193
    Wow this is great Marko!!
    This is definitely a helpful tool
    Thanks
    ~Greg
    ~Greg B
    Have fun!! www
  3. #23
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2014
    Feb 2010
    1,243
    Thanks Greg, I've cleaned code further more... Had mistake in checking weather picked entities belong to curve entities... Now fixed that issue and also changed defined functions to be local to main command function... This version I use now in my start-up acaddoc.lsp...
    Code:
    (defun c:exb2c ( / colect_entdata store_entdata colect_modified_entdata sel_mod_ents
                       hig osm c1 c2 p ss entdata )
      (defun colect_entdata ( / ss i ent entdata )
        (setq ss (ssget "_X"))
        (setq i -1)
        (while (setq ent (ssname ss (setq i (1+ i))))
          (setq entdata (cons (entget ent) entdata))
        entdata
      (defun store_entdata nil
        (setq entdata (colect_entdata))
      ;;; Modify entities ;;;
      (defun colect_modified_entdata ( / ss i ent entdatachk entdatamod )
        (setq i -1)
          (setq entdatachk (cons (entget ent) entdatachk))
        (foreach data entdatachk
          (if (not (vl-some '(lambda ( x ) (equal x data 1e-6)) entdata))
            (setq entdatamod (cons data entdatamod))
        entdatamod
      (defun sel_mod_ents nil
        (setq ss (ssadd))
        (foreach data (colect_modified_entdata)
          (ssadd (cdr (assoc -1 data)) ss)
      ;;; Main function ;;;
      (vl-load-com)
      (setq hig (getvar 'highlight))
      (setq osm (getvar 'osmode))
      (setvar 'osmode 0)
      (if (not (or etrim (not (vl-catch-all-error-p (vl-catch-all-apply 'load (list (findfile "extrim.lsp")))))))
          (alert "\nExpress Tool EXTRIM not available - quitting...")
          (exit)
      (setq c1 (car (entsel "\nPick first curve")))
      (while (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartparam (list c1)))
        (prompt "\nPicked entity isn't curve entity. Try again...")
      (setq c2 (car (entsel "\nPick second curve")))
      (while (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartparam (list c2)))
      (initget 1)
      (setq p (getpoint "\nPick or specify point between 2 prviously picked curves where do you want extrim to be processed : "))
      (store_entdata)
      (etrim c1 p)
      (sel_mod_ents)
      (command "_.copybase" '(0.0 0.0 0.0) ss "")
      (command "_.undo" "3")
      (etrim c2 p)
      (command "_.pasteclip" '(0.0 0.0 0.0))
      (setvar 'osmode osm)
      (setvar 'highlight hig)
    HTH, M.R.
    M.R. on YouTube
  1. Adding " Extrim" command to my Tool Platte
    By samifox in forum AutoCAD General
    Last Post: 31st Jan 2013, 04:49 pm
  2. Extrim not working in lisp
    By BIGAL in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jan 2013, 12:53 am
  3. 2D circle jagged lines, 3D model " hidden" jagged lines. How do i get smooth lines?
    By richarda2012 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th Oct 2012, 09:21 am
  4. Extrim command
    By chizifreshi in forum AutoCAD General
    Last Post: 30th Jan 2012, 02:57 pm
  5. Replies: 16
    Last Post: 3rd Dec 2008, 03:45 pm
Tags for this Thread
