Results 1 to 5 of 5
    Forum Newbie
    LDD 2009
    Aug 2014
    3
    Default Fatal Error on LDD 2009
    I'm new at the forum and have to get a drawing out the door. I am a surveyor. Here's what I have, It just started. When I go to import points, then click the folder for the destination of the .txt or ascii file it gives me a fatal error. Never had this happen. I did open up another drawing someone set me that was pretty old but I did have any problems with it. Also, it remember the last destination folder and I tried to import it and it had no problem. So I put that folder on the jump drive to see if it would give me a fatal error and didn't, just couldn't find it, but when I click the folder icon(destination folder for .txt) I get a fatal error every time. Any Ideas????
    Thank you.
    Forum Newbie
    MDT 2009
    Aug 2014
    Miami, FL
    6
    I am having the same issue in LDC2009 Win7 64bit but the Vertical Alignment Editor does NOT open. Anyone have any idea of this problem?
    Forum Newbie
    LDD 2009
    Aug 2014
    3
    Default Fatal Error
    stevendrew12, I went in and changed the point settings and it worked. If you need to know my point setting, I can email them to you. Greg.
    Also, do you or anyone else know how to get the dialog boxes back up. For example, when I do a "save as" I get moved to the command line like I'm back in Dos or something. Happens now with a lot of commands that are in my toolbar. This all started happening when I downloaded the Free TrueView from AutoCAD to convert newer drawings to older versions. Thanks. Greg.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,154
    Check the Value of FILEDIA
    FILEDIA
    See Also
    Switch Between Dialog Boxes and the Command Line
    Type: Integer
    Saved in: Registry
    Initial value: 1
    Suppresses display of file navigation dialog boxes.
    0 Does not display dialog boxes. You can still request a file dialog box to appear by entering a tilde (~) in response to the command's prompt. The same is true for AutoLISP and ADS functions.
    1 Displays dialog boxes. However, if a script or AutoLISP/ObjectARX™ program is active, an ordinary prompt is displayed.
    And CMDDIA
    CMDDIA
    See Also
    Create and Modify Leaders
    Type: Integer
    Saved in: Registry
    Initial value: 1
    Controls the display of the In-Place Text Editor for the LEADER and QLEADER commands.
    0 Off
    1 On
    also ATTDIA
    ATTDIA
    See Also
    Insert Blocks
    Type: Integer
    Saved in: Registry
    Initial value: 0
    Controls whether the INSERT command uses a dialog box for attribute value entry.
    0 Issues Command prompts
    1 Uses a dialog box
  5. #5
    Forum Newbie
    LDD 2009
    Aug 2014
    3
    Default Thanks
    Thanks so much. I am getting dialog boxes now. Do you know any good resources for learning IntelliCAD? My computer crashed and I am having to learn Carlson 2015 with IntelliCAD. I am coming from LDD2009. Thanks.
  1. fatal error unhandled access violation writing Error prb
    By bercha85 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 17th Jan 2011, 03:34 pm
  2. 2010 Error - FATAL ERROR: Unhandled e0434f4dh Exception at 770f76fdh
    By ezdanny in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 1st Sep 2010, 04:53 pm
  3. revit 2009 fatal error prompt
    By darris07 in forum Revit General
    Last Post: 3rd Dec 2008, 05:09 pm
  4. AutoCAD 2009 fatal error when trying to use DIMSTYLE
    By Mark R in forum AutoCAD General
    Last Post: 11th Sep 2008, 03:53 pm
Tags for this Thread
