willb Posted August 22, 2014 Share Posted August 22, 2014 Hi, When i'm inside a command such as rotate, and the visual style is realistic before initiating the command, then I realise that i'll need to be in x-ray to see some lines switching visual style by clicking on the view port controls cancels the command and makes me start all over again. Is the correct behaviour, not possible to change VS mid command? Quote Link to comment Share on other sites More sharing options...
neophoible Posted August 22, 2014 Share Posted August 22, 2014 Correct, you cannot use this command transparently. Typing a single quote (') before a command invokes it transparently. If it is not thus available, AutoCAD will tell you so. In this case, 'VSCURRENT will give you such a msg. Quote Link to comment Share on other sites More sharing options...
