moneyweather Posted August 22, 2014 Share Posted August 22, 2014 I was installing autocad 2014 when an error message pop up. It says insert disc 1. I have a disc already installed. am really confused Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 22, 2014 Share Posted August 22, 2014 I assume disk 1 was already in the drive. So what did you do? Quote Link to comment Share on other sites More sharing options...
moneyweather Posted August 22, 2014 Author Share Posted August 22, 2014 That was the error message. When I googled I was asked to copy the cd to my harddisk i.e install form my harddisk and not from the cd itself. That I have not done yet, I want to be very sure Quote Link to comment Share on other sites More sharing options...
moneyweather Posted August 22, 2014 Author Share Posted August 22, 2014 my RAM size is 2G , Can it be the RAM size Quote Link to comment Share on other sites More sharing options...
moneyweather Posted August 22, 2014 Author Share Posted August 22, 2014 I 've just solved the problem. Just copy to the desktop and run setup. Thanks @ Remark for ur suggestion Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 22, 2014 Share Posted August 22, 2014 I hadn't made the suggestion previously but that's where I was headed as I had the same problem trying to install AutoCAD 2011. Glad to hear you solved the problem on your own and thank you for updating us. BTW...you might want to consider bumping up your RAM to at least 4GB. If you plan on doing any 3D work 8GB might be better. Just a suggestion. Welcome to the CADTutor forum. Quote Link to comment Share on other sites More sharing options...
moneyweather Posted August 22, 2014 Author Share Posted August 22, 2014 Am trying to activate the product but dont know where the xforce keygenerator is Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 22, 2014 Share Posted August 22, 2014 (edited) xforce keygenerator? Where exactly did you get your software from? Is this a "cracked" version? Your delayed response only leads me to believe that you have obtained an illegal copy of the program. CADTutor does not condone the use of illegal software. I will not assist you in finding/using a key generator. Did you know there are free and low cost versions of CAD programs available? If you are a student did you know AutoDesk makes available, for free, most of their programs to educators and students? Edited August 22, 2014 by ReMark Quote Link to comment Share on other sites More sharing options...
stevendrew12 Posted August 28, 2014 Share Posted August 28, 2014 You should also check your hardware configuration.You can also try it to install it into another partition of your disk. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 28, 2014 Share Posted August 28, 2014 You should also check your hardware configuration.You can also try it to install it into another partition of your disk. Both suggestions will do the OP no good as the software is illegal. The reference to XForce keygenerator is the tip off. Quote Link to comment Share on other sites More sharing options...
moneyweather Posted September 1, 2014 Author Share Posted September 1, 2014 No Qualms, all issues have been resolved. I' ve used the Xgen to cracked the software. Quote Link to comment Share on other sites More sharing options...
