How can i select object in paper viewport in vba
Thienthanh81l
Hi, my friends,
Please, help me. I need the code which can select objects in model space through paperview port.
Thanks,
Thank BlackBox, I know CHSPACE command but it can not use for my purpose. I have some drawing which were exported from Tekla software. Everything is OK except all dimensions were exploded. So i want to write a small program to change these dimensions to AutoCad format automaticly. Please, help me if you know to solve my proplem or any suggestion to do this.
Edited by Thienthanh81l
I would go down the same path as blackbox if you have some form of dim lines in paperspace I would create two points and chspace them then dim in model space.
