mfahadrazzaq Posted August 25, 2014 Share Posted August 25, 2014 How can i remove this Error Registration-Activation Error (0015.111) in AUTOCAD 2014 Please help me Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 25, 2014 Share Posted August 25, 2014 You might want to do a general Internet search on the error code you are seeing. Or visit the AutoDesk website and search there. Are you trying to load this program on a second (possibly a laptop) computer? Where did you obtain your copy of AutoCAD 2014 from? Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 26, 2014 Share Posted August 26, 2014 You should NEVER post an activation code in a public form. I'd take that down immediately. In the market? What market? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 26, 2014 Share Posted August 26, 2014 You have posted personal Serial Number on an open forum, not a good idea. What is "Market"? url please! What is X-FORCE? Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 26, 2014 Share Posted August 26, 2014 I think Xforce is a key generator in which case the OP may have purchased his copy of AutoCAD outside the normal channels. Key generators are programs used to generate keys for pirated software. mfa: CADTutor does not condone the use of illegal (pirated) software. Quote Link to comment Share on other sites More sharing options...
mfahadrazzaq Posted August 26, 2014 Author Share Posted August 26, 2014 hmmmmmmmmmmm sorry dear sir Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 26, 2014 Share Posted August 26, 2014 The problem with some key generators is that in the process of downloading them users also unknowingly download viruses and/or malware. You get more than you bargained for and not in a good way. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted August 26, 2014 Share Posted August 26, 2014 You should NEVER post an activation code in a public form. Actually - the Activation Code is is irrelevant as it would only work for one particular machine. It is the Serial Number (if it had been valid) that can be used by anyone. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 26, 2014 Share Posted August 26, 2014 The serial number. OK. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 26, 2014 Share Posted August 26, 2014 If you're using xforce to generate an activation code then you have a pirated copy of the program. So, if you did in fact contact Autodesk for assistance, you may have just jumped from the frying pan into the fire. Good luck with that. Quote Link to comment Share on other sites More sharing options...
