AIberto Posted August 26, 2014 Share Posted August 26, 2014 (edited) Hi Dear friend: Have time to help me? I appriciate your help! My frist topic in Cadtutor http://www.cadtutor.net/forum/showthread.php?86230-How-to-drawing-Taper-Pipe-Threads I want use lisp to draw that. Drawing BSP Taper Internal thread Like this: [ATTACH]50559[/ATTACH] I want Pick up two point, draw thread. Note: Two Point (PT1&PT2) not on a horizontal or vertical line. Maybe on a tilted line, like this: [ATTACH]50555[/ATTACH] Cadtutor.com has asimilar Topic: http://www.cadtutor.net/forum/showthread.php?86379-Draw-countersink Thread size & parameter. [ATTACH]50558[/ATTACH] I think need a dialog like this: I hope all options in dialog can memory. Edited September 3, 2014 by AIberto Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 26, 2014 Share Posted August 26, 2014 I think the Dynamic Block should be able to make them in one Block with the options fore-said above , I did not try but you can start with . Quote Link to comment Share on other sites More sharing options...
AIberto Posted August 27, 2014 Author Share Posted August 27, 2014 I think the Dynamic Block should be able to make them in one Block with the options fore-said above , I did not try but you can start with . I think Use Lisp is batter. Can use 2 point specified angle. Can you help me? Tharwat. you are a great lisper , And ready to help others . Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 27, 2014 Share Posted August 27, 2014 I think Use Lisp is batter. Can use 2 point specified angle. Can you help me? Tharwat. you are a great lisper , And ready to help others . Thanks for the compliment Alberto , it is very kind of you to say that . Can you upload a sample drawing with one of these tapers ? Quote Link to comment Share on other sites More sharing options...
AIberto Posted August 27, 2014 Author Share Posted August 27, 2014 Thanks for the compliment Alberto , it is very kind of you to say that . Can you upload a sample drawing with one of these tapers ? Thanks! Tharwat. Here is the sample drawing. test.dwg Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 27, 2014 Share Posted August 27, 2014 I will work on complete program for you , so just be patient because it needs time to become with a good one . If you need to add more Thread Sizes to the dialog , just post them here to allow me to add them to the program besides that , the program would be compiled that you can not modify and this would be considered private . Just let me know if you still interested . Quote Link to comment Share on other sites More sharing options...
AIberto Posted August 28, 2014 Author Share Posted August 28, 2014 I will work on complete program for you , so just be patient because it needs time to become with a good one . If you need to add more Thread Sizes to the dialog , just post them here to allow me to add them to the program besides that , the program would be compiled that you can not modify and this would be considered private . Just let me know if you still interested . OK! No problem. I don't understand programming, I'm just the draftsman . Quote Link to comment Share on other sites More sharing options...
77077 Posted August 28, 2014 Share Posted August 28, 2014 I will work on complete program for you , so just be patient because it needs time to become with a good one . If you need to add more Thread Sizes to the dialog , just post them here to allow me to add them to the program besides that , the program would be compiled that you can not modify and this would be considered private . Just let me know if you still interested . Haha. It's also a solution. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 28, 2014 Share Posted August 28, 2014 OK! No problem. I don't understand programming, I'm just the draftsman . Do you have any more Thread Styles than these you included the above green table ? If yse , just post them here to allow me to include them in the program . Haha. It's also a solution. I don't like sarcastic manner that holds no respects . Quote Link to comment Share on other sites More sharing options...
AIberto Posted August 28, 2014 Author Share Posted August 28, 2014 It was enough. Thanks ! Tharwat. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 28, 2014 Share Posted August 28, 2014 It was enough. Thanks ! Tharwat. All right . Last question , I think have a look at the image and let me know if the extensions of the center lines are static with the current value or you want to adjust them according to any criteria ? Quote Link to comment Share on other sites More sharing options...
AIberto Posted August 28, 2014 Author Share Posted August 28, 2014 Not static value .is ratio value . 0.1*(The length between PT1 to PT2) . Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 28, 2014 Share Posted August 28, 2014 Try it and let me know . BSP.rar Quote Link to comment Share on other sites More sharing options...
AIberto Posted August 28, 2014 Author Share Posted August 28, 2014 Try it and let me know . Thanks,Tharwat. It's nice ! There is a little defective 1.The extensions of the center lines are static with the current value (1.34) This is not what I want . I want : 0.1*(The length between PT1 to PT2) . 2.The centerline of the linear scale set to 0.5 Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 28, 2014 Share Posted August 28, 2014 1.The extensions of the center lines are static with the current value (1.34) This is not what I want . I want : 0.1*(The length between PT1 to PT2) I am sorry , I considered the length of the Taper , so I have to change it as you want . no problem . 2.The centerline of the linear scale set to 0.5 Not clear enough . explain it more . Quote Link to comment Share on other sites More sharing options...
AIberto Posted August 28, 2014 Author Share Posted August 28, 2014 Not clear enough . explain it more . sorry.I mean the linetype scale set to 0.5 (centerline) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 28, 2014 Share Posted August 28, 2014 Try this modified program now and let me know . BSP.rar Quote Link to comment Share on other sites More sharing options...
AIberto Posted August 28, 2014 Author Share Posted August 28, 2014 Try this modified program now and let me know . OK! very nice! There is no problem! Big big big big big thanks! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 28, 2014 Share Posted August 28, 2014 OK! very nice! There is no problem! Big big big big big thanks! You are most welcome Alberto Quote Link to comment Share on other sites More sharing options...
77077 Posted August 28, 2014 Share Posted August 28, 2014 Nice Routine! Good man! I don't like sarcastic manner that holds no respects . Not sarcastic! You help people, I applauded ! Don't misunderstand . Quote Link to comment Share on other sites More sharing options...
