Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member
    AutoCAD 2007
    Aug 2014
    64
    Default Oblique dimension
    dimaligned & dimlinear oblique.
    can multi-select .
    use "<" key to negative direction of diminishing , once "5" degree. eg: -85 , -80 ,-75,......still -15
    use ">" key to positive direction of diminishing , once "5" degree. eg: 85 , 80, 75....
    still 15 .
    Full Member
    AutoCAD 2007
    Aug 2014
    64
    like this:
    Senior Member ketxu's Avatar
    ketxu's Computer Details
    Sorry, my English not well :(
    AutoCAD 2007
    Sep 2010
    205
    What do you want ? A request ?
    Full Member
    AutoCAD 2007
    Aug 2014
    64
    Quote Originally Posted by ketxu View Post
    I want a simple routine to do this. Thanks!
  5. #5
    Full Member
    AutoCAD 2007
    Aug 2014
    64
    Is easy or difficult?
  6. #6
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2017
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,249
    How could you modify the dimension to be in that shape ?
    I mean what are the properties to change ?
  7. #7
    Full Member
    AutoCAD 2007
    Aug 2014
    64
    Quote Originally Posted by Tharwat View Post
    COMMAND: _dimedit----> O
    OR Menu----> Dimension----> Oblique
  8. #8
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,249
    Try this .
    Code:
    Deleted
  9. #9
    Full Member
    AutoCAD 2007
    Aug 2014
    64
    Try this .
    Thanks !
    Can use keyboard do adjusted value ?
    use ">" key to positive direction of diminishing , once "5" degree. eg: 85 , 80, 75.... still 15 .
  10. #10
    Mechanical
    Mechanical
    AutoCAD 2017
    Oct 2009
    6,249
    I did not get your request enough .
  1. Oblique dimensioning problem
    By s3101959 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Aug 2012, 02:56 pm
  2. lost oblique arrowhead
    By kduck63 in forum AutoCAD Drawing Management & Output
    Last Post: 30th Apr 2012, 09:48 am
  3. oblique dimension continuous setting
    By rock1 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 11th Jan 2012, 04:00 pm
  4. Oblique Dims with VBA
    By -KarL- in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Nov 2008, 01:50 pm
  5. Oblique Text
    By chixwithtrix in forum AutoCAD General
    Last Post: 6th Apr 2005, 02:51 am
