+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Senior Member Sbeth85's Avatar
    Using
    Architecture 2014
    Join Date
    Sep 2013
    Posts
    181
    Default Multileader problem- adding new leader to vertex
    Whenever I try to add another leader to my vertex, it usually jumps to the end of the line. Any way to make ALL leader arrows come out of the same vertex?
    Do I need to adjust my mleaderstyle settings?2014-08-27 11_51_36-AutoCAD Architecture 2014 - English - [R_M Presidential Suite Alrov.dwg].jpg
    PS- I recorded a GIF with LICEcap but the File Upload Manager on Cadtutor uploads it as a JPG for some reason.
  2. #2
    Full Member
    Computer Details
    dal-designs's Computer Details
    Operating System:
    Windows 7
    Computer:
    HP Compaq Elite 8300 SFF
    Discipline
    Construction
    dal-designs's Discipline Details
    Occupation
    Designer in Oil and Gas Industry
    Discipline
    Construction
    Details
    facilities planning (retail/wholesale fuels and chemicals) aerial surveying and GIS mapping; building design, facilities planning, land development
    Using
    AutoCAD 2015
    Join Date
    Feb 2014
    Location
    Victoria, Texas
    Posts
    54
    Default
    Wow. Old thread, but it looks like you never got an answer- personally, I hate when no one bothers to answer a question I post. I ran into the same problem and I think I may have a solution for you:
    1) Select leader you wish to move and right-click;
    2) Select 'add vertex' from the drop-down menu;
    3) You can now grab the new vertex and slide it to wherever you want the leader to originate.
    Sucking at something is the first step to being kinda good at it
Similar Threads
  1. Leader/text to multileader
    By pmcwilliams in forum AutoCAD General
    Last Post: 30th Aug 2017, 04:26 pm
  2. Question about vertex / leader options. (Inventor 2011)
    By Ardalee in forum Autodesk Inventor
    Last Post: 12th Apr 2012, 03:04 pm
  3. Adding a Vertex
    By tennis4you in forum AutoCAD Beginners' Area
    Last Post: 24th May 2011, 01:30 pm
  4. Multileader to text/leader
    By Dman2900 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Sep 2009, 01:45 pm
  5. Multileader: Gap between leader & Arrowhead
    By spidercad in forum AutoCAD Beginners' Area
    Last Post: 2nd Jul 2009, 02:32 am
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
