anindya Posted August 27, 2014 Share Posted August 27, 2014 I have two alignment i have to know the chainage that the perpendicular offset from first alignment at fixed chainage makes to the second alignment.then what those chainage will be ? Pls help to figure out that.i am attaching one sample drawing.is it possible with lisp or vba? NEED HELP CHAINAGE OF ALIGNMENT.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 28, 2014 Share Posted August 28, 2014 Its know as the Peg & shift, is it possible more than likely, there is a lisp called batter ticks it works out sq off 1 pline to another it would be a good starting point if know one posts an answer. You need to specify the rules ie even chainages plus IP's ? Or just pick point and display or all output as a TXt file ? Manual method is draw line from point on pline to other pline use trim then List pline will give length then undo twice and repeat. Quote Link to comment Share on other sites More sharing options...
anindya Posted August 28, 2014 Author Share Posted August 28, 2014 i need the chainages and points id both together in drawings by vba or lisp. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted August 28, 2014 Share Posted August 28, 2014 Does it mean for instance that you want to select the yellow line ( Polyline ) and get the perpendicular lines coordinate at the intersection point between each others ? Quote Link to comment Share on other sites More sharing options...
anindya Posted August 28, 2014 Author Share Posted August 28, 2014 i want to know the chainage and id of that location where the perpendicular lines coming from yellow line intersects the green line.it should be display in drawing and in textfile.is it possible via vba or lisp? pls help me Quote Link to comment Share on other sites More sharing options...
pBe Posted August 28, 2014 Share Posted August 28, 2014 How'd you come up with the first chainage? Did you use a code for that or manually placed all the text and lines? We can add an option to the original if you have indeed used a lisp program for that. Otherwise tell us the parameters for the second alignment. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 29, 2014 Share Posted August 29, 2014 An example two alignments built in to our ARD software. Note 1st CH at 10m spacing plus tp's Main Alignment CL1 Offset Alignment CL2 Pegged Shifted Offset 0.000 10.000 20.000 7.640 57.113 30.000 17.657 56.525 40.000 27.675 55.937 50.000 37.692 55.349 Quote Link to comment Share on other sites More sharing options...
anindya Posted August 29, 2014 Author Share Posted August 29, 2014 i did not used any lisp for chainage marking of 1st alignment.i used geotools.i wanted to know the exact chainage of second alignment location where the perpendicular line coming from first alignment crossing the second alignment,if i am using the tools it will mark similarly the second alignment on any fixed interval but it is unable to provide the exact chainage of intersection,then manullly i have to measure the distance of intersection point from near chainage .it is timetaking so i need help for that one.is it possible by vba?in landdesktop i observed that one option was there to trace station offset chainage like that,but there also the user has to click every intersection point.is that possible by one click in vba??????? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 29, 2014 Share Posted August 29, 2014 You need to specify the rules Like I said in my first post do you just want random pts ie pick point it can be a known chainage eg 10 which has a station marker you can snap to or a list of chainages required. Your dwg seems to be just random pts ? Or do you want to pick pts on second alignment and get chainage from 1st alignment ? Please post a clearer dwg of the task Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted August 29, 2014 Share Posted August 29, 2014 (edited) Every 500 units on the yellow polyline you draw a perpendicular line. Now, you want a list of all the intersections between the green polyline and the perpendicular lines. right? Some questions - Why is the yellow curve a 3D polyline? The curve is flat; I presume a normal polyline is what you need. Any z-value would make it impossible to find intersects. - What exactly do you need, what is the end result supposed to be: the white lines, trimmed and/or extendended? The intersections? Do you want a list printed somewhere? ... EDIT: oh yes, you want it exported to a .txt file. That's no problem. What format? Can you show an example of that text file, what the end result could look like, for a few points - Would you expect the green curve ever to cross/intersect the yellow curve? Then the extend would sometimes be on the other side. Edited August 29, 2014 by Emmanuel Delay Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted August 29, 2014 Share Posted August 29, 2014 (edited) I think this is what you want. (If it isn't, it does what my previous post suggests) COMMAND: PERP At the end, look at the command bar: you get a list of the intersection points (of the Xlines with the secondary curve). I just don't know what your intentions are with those points. (You won't hear from me before monday) ;; @file: measure a curved line; every 500 units draw a perpendicular line. We are looking for the intersection of the perpendicular lines with a second curved line ;; @author: Emmanuel Delay - emmanueldelay@gmail.com ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; resources ... (vl-load-com) (setq modelSpace (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-Acad-Object)))) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; main function (defun perp (dist / curve-obj curve-second points xlines intersections) (setq curve-obj (entsel "\n Select a curve:") ;; client selects the curved object, to be measured curve-second (entsel "\n Select a second curve:") ;; client selects the second object; points (getMeasurePoints dist curve-obj) ;; list of all the points. From those points we draw the perpendicular lines xlines (drawPerpendicularLines points curve-obj curve-second) ;; Construction lines (xline) intersections (getIntersections xlines curve-second) ;; returns a list of intersection points ) (princ "\nIntersection points:\n") (princ intersections) ) ;; measures a polyline, returns a list of points, all "dist" away from each other, along the curve (defun getMeasurePoints (dist curve / points needle pt) (setq needle dist points (list) pt nil ) (while (and ;; repeat while vlax-curve-getPointAtDist keeps finding a new point (setq pt (vlax-curve-getPointAtDist (car curve) needle)) (/= nil pt) ) (setq points (append points (list pt)) ) (setq needle (+ needle dist)) ) points ) (defun drawPerpendicularLines (points curve curve-second / i pt p xlines vl-obj x) (setq i 0 xlines (list) ) (repeat (length points) (setq pt (nth i points)) (setq vl-obj (vlax-ename->vla-object (car curve))) (setq x (vlax-curve-getParamAtPoint vl-obj (setq p (vlax-curve-getClosestPointTo vl-obj pt) ) ) ) (setq xlines (append xlines (list (drawPerpendicularLine curve curve-second x pt)) )) (setq i (+ i 1)) ) xlines ) (defun drawPerpendicularLine (curve curve-second param pt / deriv PTDERIV ptg xline) ;; @see http://cadxp.com/topic/21475-vlax-curve-getfirstderiv/ (setq deriv (vlax-curve-getFirstDeriv (vlax-ename->vla-object (car curve)) param)) (setq PTDERIV (mapcar '+ pt deriv)) ;; get a point, distance 10000.0, angle: perpendicular (setq ptg (polar pt (+ (angle pt PTDERIV) (/ pi 2)) 10000.00)) (setq xline (drawXline ptg pt)) xline ) (defun getIntersections (xlines curve-second / i intersects) (setq i 0 intersects (list) ) (repeat (length xlines) (setq intersects (append intersects (list (vlax-invoke (nth i xlines) 'IntersectWith (vlax-ename->vla-object (car curve-second)) 3) ))) (setq i (+ i 1)) ) intersects ) (defun drawXline (p1 p2) (vla-AddXline modelSpace (vlax-3d-point p1) (vlax-3d-point p2)) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; command PERP (defun c:perp ( / ) (perp 500) (princ) ) Edited August 29, 2014 by Emmanuel Delay Quote Link to comment Share on other sites More sharing options...
pBe Posted August 29, 2014 Share Posted August 29, 2014 (edited) ...i wanted to know the exact chainage of second alignment location where the perpendicular line coming from first alignment crossing the second alignment,... (defun c:pso ( / cl1 cl2 d pt pt2 templine ang spc ) ;;; pBe 30Aug2014 ;;; (if (and (princ "\nSelect the main alignment") (setq cl1 (ssget "_:S" '((0 . "*POLYLINE")))) (princ "\nSelect the offset alignment") (setq cl2 (ssget "_:S" '((0 . "*POLYLINE")))) ) (progn [color="blue"] (setq d (cond ((getdist (strcat "\nEnter increment value: " " <" (rtos (setq d (cond ( d_ ) ( 100.00 )) ) 2 2) ">: "))) ( d ) ) )[/color] (setq cl1 (ssname cl1 0) cl2 (ssname cl2 0) d_ d) (while (setq pt (vlax-curve-getpointatdist cl1 d)) (setq ang (angle '(0.0 0.0 0.0) (vlax-curve-getfirstderiv cl1 (vlax-curve-getparamatpoint cl1 pt) ) ) ) (setq templine (vlax-invoke (setq spc (vlax-get (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object ))) 'Block)) '[color="blue"]AddXline[/color] pt (polar pt (setq ang (+ ang (* pi 1.5))) 1)) ) (if (setq pt2 (vlax-invoke templine 'IntersectWith (vlax-ename->vla-object cl2) 0 ) ) [color="red"] (vlax-invoke spc 'Addline pt (list (Car pt2)(cadr pt2)(caddr pt2)))[/color] ) (vla-delete templine) (setq d (+ d d_)) ) ) ) (princ) ) (vl-load-com) command: pso Edited August 30, 2014 by pBe Xline in place of Ray / Add default / To account if there are more than one intersection 1 Quote Link to comment Share on other sites More sharing options...
