Replace Attributes with the Correct Values
nod684
Good morning peeps...
asking for your kind assistance. I have attached here 2 files. One is the Exploded and the other is the Attribute Block to be used.
For some "silly" reason, our drafter inserted the exploded attributes, edit the Attribute tag with the correct value which should have been inputed in the value.
in the screenshot below :
the word SECTION is one word so as with the G,- and another G
so all in all
SECTION G-G composed of 4 words inputed in the TAG instead of the value.
We have a bunch of drawings here and is due end of next week.
just wondering if there is a better work around on this matter rather than opening it one by one and inputing the text. Please see attached files
is there a way for me to insert the Attribute Block, and the routine will replace the correct values from the "exploded" block" to the inserted AttBlock?
Exploded.dwg
X-SLB-A1_Title.dwg
Do you want this Automagically? No user intervention at all.
command: reatt
Done
Something like that? or would you a allow user to select at least one reference ATTDEF ? How many of these drawings do you need to "repair"?
EDIT: Scratch that, i think it can be done without user intervention
EDIT 2: How did ended up like this in the first place? anyhoo, looking at your sample drawing, The "DRAWING-TITLE-LINE-3" ATTDEF is broken down into 3. will be it always like that? or sometimes there's only 1 or
DRAWING-TITLE-LINE-4 is broken down into 2?
Edited by pBe
command: reatt
Done
if possible yes...
i have less than 300
What of the other item?
it should not be like that..
it should be 5 Drawing Title Lines (see X-SLB-A1_Title.dwg)
i'm guessing he copied that from somewhere maybe binded / exploded drawing.
I think i have an idea right on top of my head. hang in there....
Its fun writing this code.. too bad its too specific to your troublesome drawings to be generic
Command: reatt
reatt.LSP
Edited by pBe
Don't you have the backup files from right before the draughtman started exploding the attributes?
Cheers
Welsey
we don't have...im guessing it was inserted as exploded and he type the contents in the TAG rather than in the values...
thanks pBe. take your time...
