Inventor Frame Generated part is inserted at a different place than I selected
vespazari
Hello all, New to the cad forum...and new to inventor after taking a two year break.
I am creating an equal angle frame member using the frame generator,
everything seems to work as per usual.
1. I select insert frame, select my iso structural section, select the dimensions of the section. then I select an edge for placement and also orientation.
The green preview looks exactly how I want it to and I click apply.
But when the frame member shows up on screen it shows up in a different location. It is like there is a offset or displacement , but the vertical and horizontal offsets are set to 0.00mm
Has anyone got any suggestions?
Thank You
Nate
