muck Posted September 3, 2014 Share Posted September 3, 2014 Using VS 2010 with AutoCAD 2013 or 2014. I am getting Fatal Execution Engine Error was detected. The runtime has encountered a fatal error. The address of the error was at 0xe79d9f1a, on thread 0x1080. The error code is 0xc0000005. This error may be a bug in the CLR or in the unsafe or non-verifiable portions of user code. Common sources of this bug include user marshaling errors for COM-interop or PInvoke, which may corrupt the stack. It is in the statement DocumentExtension.CloseAndSave(acDocMgr.MdiActiveDocument, strFileName) How do I begin to trouble shoot this? Thank you, Quote Link to comment Share on other sites More sharing options...
muck Posted September 3, 2014 Author Share Posted September 3, 2014 I am using the following code in a loop. Public Class MyCommands <CommandMethod("OSCLoop", CommandFlags.Session)> _ Public Sub OSCLoop() ' This method can have any name ' Put your command code here Dim y As Integer Dim lines() As String = IO.File.ReadAllLines("C:\VBdwgFilelist.txt") Dim strFileName As String Dim lineArray As New ArrayList() Dim acDocMgr As DocumentCollection = Application.DocumentManager Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Dim obj As Object = Application.GetSystemVariable("DWGTITLED") y = 0 For x As Integer = 0 To lines.GetUpperBound(0) 'If TextBox1.Text = String.Empty Then If lines(x) <> String.Empty Then lineArray.Add(lines(y)) y = y + 1 End If Next 'MsgBox("Show each line") For x = 0 To lineArray.Count - 1 'MsgBox(lineArray.Item(x)) 'Open the drawing strFileName = lineArray.Item(x) MsgBox(strFileName) If (File.Exists(strFileName)) Then DocumentCollectionExtension.Open(acDocMgr, strFileName, False) 'START SAVE & CLOSE 'DocumentExtension.CloseAndDiscard(acDocMgr.MdiActiveDocument) DocumentExtension.CloseAndSave(acDocMgr.MdiActiveDocument, strFileName) MsgBox("Drawing Saved") Else acDocMgr.MdiActiveDocument.Editor.WriteMessage("File " & strFileName & " does not exist.") End If Next End Sub End Class Quote Link to comment Share on other sites More sharing options...
