Results 1 to 4 of 4
    Full Member
    AutoCAD 2008
    Apr 2012
    62
    Wink attribute in model not show
    hi all
    can you help me i have ablock table cotain text as attribute value and when make layout it show me this table without attribute vale just table
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Attach a copy of a drawing to your next post that contains the block. Someone here will take a look at it.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    There are a few ways this could happen.
    Most common is probably a layer frozen in the viewport.
    My guess would be that it is an annotative scale issue.
    Drafting is a breeze.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Did you try ATTSYNC?
    ATTSYNC
    See Also
    Modify a Block Attribute Definition
    Updates block references with new and changed attributes from a specified block definition.
    Access Methods
    Button
    Ribbon: Home tabBlock panelSynchronize Attributes
    Toolbar: Modify II
    Command entry: attsync
    Summary
    You are prompted for the names of blocks you want to update with the current attributes defined for the blocks.
    Use this command to update all instances of a block containing attributes that was redefined using the BLOCK or BEDIT commands. ATTSYNC does not change any values assigned to attributes in existing blocks.
    Note:
    Use the ATTREDEF command to redefine and update blocks in one command.
    Entering ? displays a list of all block definitions in the drawing. Enter the name of the block you want to update.
    Pressing ENTER allows you to use your pointing device to select the block whose attributes you want to update.
    If a block you specify does not contain attributes or does not exist, an error message is displayed, and you are prompted to specify another block.
    Warning
    ATTSYNC removes any format or property changes made with the ATTEDIT or EATTEDIT commands. It also deletes any extended data associated with the block, and might affect dynamic blocks and blocks created by third-party applications.
    Attach the drawing if possible.
  1. Show attribute value rotated
    By sadhu in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Jan 2012, 01:57 pm
  2. How show a partical block attribute Name in a Field?
    By muck in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Feb 2011, 07:33 pm
  3. Replies: 2
    Last Post: 19th Jul 2010, 06:42 pm
  4. How to show hidden lines of a 3d model.
    By humaironline in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Jun 2009, 04:57 am
  5. Replies: 7
    Last Post: 5th Feb 2008, 08:37 am
