anindya Posted September 4, 2014 Share Posted September 4, 2014 I have attached one sample drawing for your observation.is it possible to make by vba ?then pls provide me the vba code for that one NEDD HELP IN GRID MAKING12121212.dwg Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 4, 2014 Share Posted September 4, 2014 I have attached one sample drawing for your observation.is it possible to make by vba ?then pls provide me the vba code for that one Since CADTutor isn't a 'drive thru' perhaps it would be better if you'd also post the code you have so far, so our volunteer members aren't being asked to code the entire thing themselves. Cheers Quote Link to comment Share on other sites More sharing options...
anindya Posted September 4, 2014 Author Share Posted September 4, 2014 i did it by array command but every time the datum is changing so i have to do it manually that is time taken so asked for help.....any how if possible provide the any lisp or any vba code to execute that for getting the desired result. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 4, 2014 Share Posted September 4, 2014 i did it by array command but every time the datum is changing so i have to do it manually that is time taken so asked for help.....any how if possible provide the any lisp or any vba code to execute that for getting the desired result. I can appreciate your motivation, but feel you may be missing the point... It doesn't matter if Visual LISP or VBA; wishing for someone else to code you an entire solution is rarely granted, without you first coding an attempt. Even then, you'll typically receive guidance on how to overcome a given roadblock, and not an entire re-write of your code. You have to put in the effort, before it is worth our volunteering time to assist. As for the logic of your problem, instead of creating an Array, perhaps you could instead either simply offset, or programmatically calculate the coordinates of the required vertices and create a new entity for each corresponding line in your grid. Good luck! Quote Link to comment Share on other sites More sharing options...
anindya Posted September 4, 2014 Author Share Posted September 4, 2014 i dont know anything about vba code or lisp.when ever i faced problem i searched here and got the solution.then i copy those as my asset to use in future in my problem.so i have lisp programme and vba what i found in net, in here or in other location,but in these case i tried but i failed.so i asked.if i get then my that issue will be solved.As a consequence my attempt in these case will not bring anything for me,but those who knows can do lots.so pls understand.i am just a user not a maker because i have no knowledge to make a vba or lisp. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 4, 2014 Share Posted September 4, 2014 Who can say for sure why some requests, like yours, go unfulfilled while others seemed to be answered/solved rather quickly. Could be influenced by any number of factors. Just try to be patient. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted September 4, 2014 Share Posted September 4, 2014 i am just a user not a maker because i have no knowledge to make a vba or lisp. I understand; I too am a user first, and have only recently learned through a lot of personal time, and the kindness of others how to become a 'maker' as you put it. I think it's great that you've had such success for finding what you need here at CADTutor, and know that *IF* a member here has the time they will help... As ReMark correctly put it, please be patient. Cheers Quote Link to comment Share on other sites More sharing options...
anindya Posted September 4, 2014 Author Share Posted September 4, 2014 ok me waiting,,,,,,,, Quote Link to comment Share on other sites More sharing options...
mustlagz Posted November 30, 2014 Share Posted November 30, 2014 see http://mustlagz.canalblog.com/archives/2014/10/06/30714514.html Quote Link to comment Share on other sites More sharing options...
RICVBA Posted November 30, 2014 Share Posted November 30, 2014 Try this one attached you can easily adapt it to your actual needs NEDD HELP IN GRID MAKING12121212.dwg Quote Link to comment Share on other sites More sharing options...
anindya Posted December 14, 2014 Author Share Posted December 14, 2014 sir please convert that drawing in lower version of cad like 2004 because me using in 2007 cant open your drawing. Quote Link to comment Share on other sites More sharing options...
RICVBA Posted December 14, 2014 Share Posted December 14, 2014 sir please convert that drawing in lower version of cad like 2004 because me using in 2007 cant open your drawing. here's a 2004 version NEDD HELP IN GRID MAKING12121212 - v2004.dwg Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 15, 2014 Share Posted December 15, 2014 Get a FREE download of DWG TrueView and you can convert newer files yourself. Quote Link to comment Share on other sites More sharing options...
