beardrafter Posted September 5, 2014 Share Posted September 5, 2014 I have to create a BOM for bolt packages. In the past we have created an excel doc and imported into the 2d in place of a BOM. Keeping track of this manually sucks. The customer needs to see the BOM similar to attached but I'm not able to find out how to setup QTY in different columns like this. Basically I need to show that a SubAssembly "HK-###" has a quantity of 2 and in that SubAssembly there are so many nuts, bolts and washers Any suggestions? Thanks Quote Link to comment Share on other sites More sharing options...
Ian12 Posted June 7, 2015 Share Posted June 7, 2015 You can make it like as firstly note down about all nuts, then bolts, washers along with his quantities. May be, its best way for customize Bom for carriage bolts. It's also looking good which you share. Good job, keep it up. Quote Link to comment Share on other sites More sharing options...
