kunekainen Posted September 6, 2014 Share Posted September 6, 2014 (edited) Edit: Solved. Thanks. Hi there. At first sorry for my English. I'm an AutoCAD VBA newbie and trying to convert a Excel VBA code to AutoCAD VBA environment. It's a macro which calculates rebar quantity and I converted some of it but i'm having trouble with this: This is a part of my original code: 'one row spanning several columns Dim Destination As Range If mainGUI.ComboBox1.Value = "Ayrı" Then Set Destination = Range("D" & i) End If If mainGUI.ComboBox1.Value = "Poz Yok" Then Set Destination = Range("D" & i) Range("C" & i).Value = 0 End If If mainGUI.ComboBox1.Value = "Birleşik" Then Set Destination = Range("C" & i) End If Set Destination = Destination.Resize(1, UBound(Arr)) Destination.Value = Arr Range("C" & i).Value = Range("C" & i).Value / 1 Range("E" & i).Value = Range("E" & i).Value / 1 Range("G" & i).Value = 1 If InStr(Range("D" & i).Value, "X") <> 0 Then posx = InStr(Range("D" & i).Value, "X") lenx = Len(Range("D" & i).Value) Range("D" & i).Value = Left(Range("D" & i).Value, posx - 1) * Right(Range("D" & i).Value, lenx - posx) Else Range("D" & i).Value = Range("D" & i).Value / 1 End If If InStr(Range("F" & i).Value, "~") <> 0 Then posx = InStr(Range("F" & i).Value, "~") lenx = Len(Range("F" & i).Value) x = Left(Range("F" & i).Value, posx - 1) y = Right(Range("F" & i).Value, lenx - posx) Range("F" & i).Value = (x + y) / 200 Else Range("F" & i).Value = Range("F" & i).Value / 100 End If The problem is I don't know how to convert Set Destination = Range("D" & i) I have an AcadTable object but as you know it hasn't got the Range object. How can I solve this. Thanks in advance for your valueable time. Edited September 6, 2014 by kunekainen Quote Link to comment Share on other sites More sharing options...
